Who makes thinnest valve cover gasket? #1227331
05/04/12 08:23 PM
05/04/12 08:23 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
Begging for help again:) Does anyone know who makes the thinnest valve cover gasket for a big block. The Felpro rubber coated fiber 3/16" is too thick but seals great. I need another 1/8" between my valve cover and the brake booster for my PCV valve to fit in. Any suggestions?
BigBlock 74 Swinger
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227332
05/04/12 08:32 PM
05/04/12 08:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Dude. 1/8" is TWO SIXTEENTHS
Use RTV or put the PCV on the other side of the engine.
Don't be the exception.
Re: Who makes thinnest valve cover gasket? [Re: Supercuda] #1227333
05/04/12 08:40 PM
05/04/12 08:40 PM
Missouri
mopar addict
mopar addict
Missouri
Steve...I know it sounds bizzarre but everything under the hood of this car is in 1/16" increments, it sucks. Do you think the RTV will work for an extended period of time? To change gaskets I have to remove the brake booster/master cylinder and AC hose on the drivers side...on the passenger side I have to remove the fan motor and fuel pressure regulator/fuel line from the electric fuel pump...just sayin:/
BigBlock 74 Swinger
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227334
05/04/12 08:42 PM
05/04/12 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I do not think RTV will work.
I dunno your combo, but it sounds very unstock. Could you possibly lower the engine?
Re: Who makes thinnest valve cover gasket? [Re: Supercuda] #1227335
05/04/12 09:04 PM
05/04/12 09:04 PM
Missouri
mopar addict
mopar addict
Missouri
You are very good...lowered the k member 3/8". That got me the hood clearance I needed. Thank for the thought Steve:)
BigBlock 74 Swinger
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227336
05/04/12 11:22 PM
05/04/12 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
anytime
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227337
05/05/12 11:39 AM
05/05/12 11:39 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Need more info on what you have
Stock heads & stock valve covers, you're stuck with the cork & rubber usually 3/16" a minimum thickness.
or
Aftermarket heads & Cast or Fabricated valve covers, I can help with this as I offer a .050" thick gasket.
If you have Stock heads with Cast or Fabricated valve covers and feel ambitious you can remove the heads and have the valve cover gasket rail machined true & flat so a thinner gasket will seal. In fact this will help ANY gasket seal better for you.
Just some food for thought wish I would have machined mine while they were off. It WILL be done next time.
Greg
Oh forgot about the rubber gaskets. I think Fel Pro or somebody makes an 1/8" rubber gasket but don't know how well they seal
Re: Who makes thinnest valve cover gasket? [Re: roadhazard] #1227338
05/06/12 08:41 PM
05/06/12 08:41 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks Greg. I have Eddy heads and the early 70's stock chrome valve covers. I'm not the brightest bulb on the tree...but how thick is .050 in inches? I might be interested in what you have. I just purchased some 3/32 gasket material and may cut my own out if I can't find something soon.
Russ
BigBlock 74 Swinger
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227339
05/06/12 09:05 PM
05/06/12 09:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Russ
1/16 is .062 so .050 is thinner. Eddy heads are taller than stock so that explains the issue .
3/32 is .093 ... thicker than 1/16 but not 1/8
Re: Who makes thinnest valve cover gasket? [Re: JohnRR] #1227340
05/07/12 09:35 AM
05/07/12 09:35 AM
Missouri
mopar addict
mopar addict
Missouri
Russ
Thank you John:) I know I should have been able to figure it out but I just couldn't get it right. I didn't realize the Eddy's were taller, but with that and the taller valve covers, it just adds to the issue. I think I'm taking the 3/32 back and try the 1/16 material.
Have always valued you input John...thanks again.
Russ
BigBlock 74 Swinger
Re: Who makes thinnest valve cover gasket? [Re: bb74swngr] #1227341
05/07/12 10:02 AM
05/07/12 10:02 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Russ
Russ save yourself some time and aggravation. The 3/32" or the .050" (approx 3/64") material WILL NOT SEAL the 70's stock chrome valve covers. They require a thicker gasket material that will conform to the surface irregularities of the stamped steel covers.
You may want to look for a fabricated valve cover and possibly have it motified for clearance in the area needed. Then you can use a thin gasket
http://store.440source.com/Valve-Covers-Fabricated-Aluminum-pair-USA-MADE/productinfo/200-1052/
Greg
Re: Who makes thinnest valve cover gasket? [Re: roadhazard] #1227342
05/10/12 12:02 PM
05/10/12 12:02 PM
Missouri
mopar addict
mopar addict
Missouri
Russ
Greg
Thank you Greg. I will take your advise rather than experience more pain:):):)
Russ...
BigBlock 74 Swinger
