Re: The all new Barry Grant Street Demon carb
[Re: Streetwize]
#1226368
05/25/12 02:26 PM
05/25/12 02:26 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
BG is listing these as having 1 3/8" primary bores, which would basically be OEM sizes for smallblocks. From http://ramchargercentral.com/engine/thermoquad-guide/:Quote:
The Thermo-Quad was available with two primary throttle bore sizes, 1-3/8" and 1-1/2". Flow ratings (CFM) vary depending on the source, but the TQs with the 1-3/8" bores are listed as 750-800 CFM and those with the 1-1/2" primary throttle bores are rated at 800-850 CFM. All TQs have the 2-1/4" diameter secondary throttle plates. The primary bore size depended on application. In general, all 78 and later 318s and 360s and all 340s had the smaller bore. Earlier 360s varied depending on application, most 400s and all 440s had the large bore. The 9000 series have the small primary bore and were rated by Carter at 800 cfm. Later TQs (ie, Lean Burn and ESA applications, feedback systems) are quoted with less flow ratings, but this is due to the control of the carburetion system, not the inherent flow capability of the basic carburetor. The internal metering is set for leaner running conditions for Lean Burn. Either bore size can be tuned to run well on most engine combinations. The smaller bore offers a slight increase throttle response but less overall flow. The different bore sizing, ie. speadbore, is an aspect that can lead to increased fuel economy while delivering similar wide open throttle (WOT) performance to an equivalent standard bore configuration. The adjustability of the TQ and the spreadbore configuration allows the use of a large CFM carburetor on a small displacement engine.
I'm curious how well this would work on a '65 413HP? I'm not sure I want to be a guinea pig for it, although if it's a bad fit I believe Summit would take it back with no questions.
And I wonder if an OEM 1 1/2" baseplate could be installed, would it fit and would it work well???
[Re: ZIPPY]
#1226369
05/25/12 06:59 PM
05/25/12 06:59 PM
Posts: 1,031 Raleigh N.C
hemiparts
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Yep I sort of gathered that....their area code changed from Georgia to Kentucky so that pretty much tells the tale.
I'm on the phone with them right now, am not expecting miracles but it doesn't hurt to let them know...
I just sent my demon back today to be checked out and it went to Dalahoga (sp) Ga. Sales maybe handled through Holley but tech must still be in GA.
Chris
[Re: cogen80]
#1226371
05/26/12 09:32 AM
05/26/12 09:32 AM
Posts: 8,946 Holly/MI
Dean_Kuzluzski
Holly/MI
Interesting product! The old Holley 3-barrel required a single-plane or you had to clearance the spot between the two secondary bores at the intake due to the oblong shape of the long/wide blade??? They would look cool and be fun (1250 cfm) on an old school T-ram!
[Re: Dean_Kuzluzski]
#1226372
11/07/12 12:19 AM
11/07/12 12:19 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I'm getting ready to bolt one on my 446 in my 1986 RC that I basically built for towing and hauling my family around. I'm hoping that it does well.
I just done a search in Google to see if someone as tried this already and found this thread.
Moparlee
[Re: Cuda367]
#1226374
11/08/12 08:11 AM
11/08/12 08:11 AM
Robbins
Joplin, MO USA
Well I'm not sure if I should post this here, but what a fight. They really didn't engineer this for us mopar guys at all.
The throttle bolt (that they say is for Chrysler and that is sold separately) wouldn't fit my accelerator cable at all.
Either side of the bolt stud....then you have to put the cable up high so that it will clear the carb stuff on the throttle linkage.
Took my four hole 1 in spacer out of it and that seem to help that, but now my three piece kick down won't even go on now cause of the throttle being to low.
They need to make bracket like Holley, and Edelbrock makes.
I guess that I have one of those and I'll try and just modify it to fit the Street Demon.
Moparlee
[Re: Robbins]
#1226375
11/08/12 09:23 AM
11/08/12 09:23 AM
Posts: 2,826 NY usa
540challenger
NY usa
there is a bracket out there for the other demons to use your stock cable and kick down , I wonder if it fits this new version hmmmmm
