Re: Chrome Box EIM - Does it Retard Advance?
[Re: JohnRR]
#1226014
05/05/12 11:46 AM
05/05/12 11:46 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Dwell ddirectly affects timing,.
not if the dwell starts earlier. it can be manipulated electronically. i've checked several orange boxes, and one chrome box, to 6000 rpm- no sign of retardation (pardon the choice of words). they are all old boxes, though. i think my newest one is over ten years old. i think ballast resistor selection is important, too. iirc, there are two resistance values available? i have always used the higher resistance, and have had no ignition issues ever (aside from a ballast resistor failing at an extremely inopportune time).
In the other thread about this subject it is claimed that there was a change made to them in 2000. So if your boxes are older than that it doesn't help with this question/problem.
But thanks anyway.
So I'm safe with my chrome box from 1989 Not to derail the thread but I've never been able to get a gold box to run at all
[Re: scatpacktom]
#1226021
05/06/12 11:50 AM
05/06/12 11:50 AM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I have a Sun distributor machine. When I first got it I thought I wasn't using it properly or that there was something wrong with it. The timing would reach full advance at whatever rpm and then at high rpm it would loose a few degrees at max rpm. Talking with other distributor machine owners, they have found the same trends. I'd still like to hear a explanation for why this happens. You would think centrifugal forces wouldn't allow it
That said I don't think I have ever seen 10 degrees only a few.
Tom do you remember what RPM were you seeing this happen at ?
