Re: Chrome Box EIM - Does it Retard Advance? [Re: JohnRR] #1226014
05/05/12 11:46 AM
05/05/12 11:46 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Dwell ddirectly affects timing,.
not if the dwell starts earlier. it can be manipulated electronically. i've checked several orange boxes, and one chrome box, to 6000 rpm- no sign of retardation (pardon the choice of words). they are all old boxes, though. i think my newest one is over ten years old. i think ballast resistor selection is important, too. iirc, there are two resistance values available? i have always used the higher resistance, and have had no ignition issues ever (aside from a ballast resistor failing at an extremely inopportune time).
In the other thread about this subject it is claimed that there was a change made to them in 2000. So if your boxes are older than that it doesn't help with this question/problem.
But thanks anyway.
So I'm safe with my chrome box from 1989
Not to derail the thread but I've never been able to get a gold box to run at all
Re: Chrome Box EIM - Does it Retard Advance? [Re: scatpacktom] #1226015
05/05/12 12:52 PM
05/05/12 12:52 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
I have a Sun distributor machine. When I first got it I thought I wasn't using it properly or that there was something wrong with it. The timing would reach full advance at whatever rpm and then at high rpm it would loose a few degrees at max rpm. Talking with other distributor machine owners, they have found the same trends. I'd still like to hear a explanation for why this happens. You would think centrifugal forces wouldn't allow it
That said I don't think I have ever seen 10 degrees only a few.
I own a marquet dist machine and i always see a high end retard on dists also, have never figured out why. As far as box I have no idea if they retard. Sorry to high jack.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Chrome Box EIM - Does it Retard Advance? [Re: kilroy] #1226016
05/05/12 01:38 PM
05/05/12 01:38 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The MP boxes don't have any intelligence in them they just pick up a signal from the distributor and use it to shut the coil on and off. The way they convert the signal is the problem.
When you get up around 4000 rpm the speed of the signal starts being a problem for the circuits to handle it.
That is the reason they show spark timing retarding. More modern systems take that signal and process it and manipulate it to do what is needed,the MP boxes are just an old design.
Keith
Re: Chrome Box EIM - Does it Retard Advance? [Re: Dunnuck Racing] #1226017
05/05/12 06:41 PM
05/05/12 06:41 PM
MassHole Central
rtman Offline OP
rtman  Offline OP
MassHole Central
Thanks, Keith.
So are the Chrome box circuits a similar (read: old) design that will have the same processing problem?
Re: Chrome Box EIM - Does it Retard Advance? [Re: rtman] #1226018
05/05/12 10:40 PM
05/05/12 10:40 PM
Northern Indiana
Northern Indiana
RTman,
The ones I have seen do the same thing,usually around 400 rpm. Different coils and pick up coils seem to make a difference on the rpm it happens in my testing,but only by a few hundred rpm either way.
Keith
Re: Chrome Box EIM - Does it Retard Advance? [Re: Dunnuck Racing] #1226019
05/06/12 01:12 AM
05/06/12 01:12 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Keith, do you have any experience with the gold boxes, to say whether they are any better or worse for dropping advance than the chrome?
Thanks,
Rick
Re: Chrome Box EIM - Does it Retard Advance? [Re: 72demon416] #1226020
05/06/12 10:58 AM
05/06/12 10:58 AM
Northern Indiana
Northern Indiana
No,the couple of gold boxes I bought about ten years ago could not be made to work. I tried a couple of cars,and went through the wiring diagrams in the MP manual to make sure it was right.
That was when I gave up on MP boxes in my cars.
Keith
Re: Chrome Box EIM - Does it Retard Advance? [Re: scatpacktom] #1226021
05/06/12 11:50 AM
05/06/12 11:50 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Tom do you remember what RPM were you seeing this happen at ?
