72 thru 74 cudas #1223716
04/28/12 07:35 PM
04/28/12 07:35 PM
North East Coast
harborracer Offline OP
North East Coast
What are some ways to tell the difference between 72-73-74 Cudas?
thanks a lot!
Re: 72 thru 74 cudas [Re: harborracer] #1223717
04/28/12 07:52 PM
04/28/12 07:52 PM
Kirkland, Washington
Pacnorthcuda Offline
Easiest way? Check the 6th digit of the VIN
Re: 72 thru 74 cudas [Re: Pacnorthcuda] #1223718
04/28/12 08:00 PM
04/28/12 08:00 PM
North East Coast
North East Coast
Theres no vin. Its just a general question so I know how to tell the 3 years apart from eachother. grills ? headlights? tail lights?
thanx !
Re: 72 thru 74 cudas [Re: harborracer] #1223719
04/28/12 08:06 PM
04/28/12 08:06 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
72 fugly grille, round tail lights.
73 fugly grille, large rubber bumper guards, round tail lights.
74, fugly grille, huge rubber bumper guards, round tail lights.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: 72 thru 74 cudas [Re: BS27R1B] #1223720
04/28/12 08:24 PM
04/28/12 08:24 PM
Connecticut
biginchmotor Offline
Connecticut
73 - 74 Barracudas had a larger trunk lock cylinder in the tail light panel held in with a large threaded nut, 72 had the 70 - 71 style trunk lock cylinder held in with a clip. Seat belts are different also. If the glass is there check out the date codes. Do you have some pictures? Especially of the grill area as I like the grill on those year Barracudas.
Re: 72 thru 74 cudas [Re: biginchmotor] #1223721
04/28/12 09:20 PM
04/28/12 09:20 PM
North East Coast
North East Coast
Thanks gentlemen.
I dont like to go by the bumper guards because they can be removed.
Biginch,that was helpful. Any differences in the grill between the three years?
Re: 72 thru 74 cudas [Re: harborracer] #1223722
04/28/12 09:43 PM
04/28/12 09:43 PM
Connecticut
Connecticut
The 72 grill will not have the screw holes for the bumper filler strip that was used on the 73-74 models. I think 73-74 model year front bumper brackets had 3 bolt holes in each front frame rail. My 72 has 2 threaded holes in the front frame rails for the bumper brackets. Also the 73-74 cars had screw holes in the body by the tail light panel for the rear bumper filler to be attached with.
Re: 72 thru 74 cudas [Re: biginchmotor] #1223723
04/28/12 10:10 PM
04/28/12 10:10 PM
North East Coast
North East Coast
Sounds like if one is driving down the highway its not so easy to determine the exact year unless your really close to it.
I was thinking the center portion of the grill where the 6 slots/vents are (3 per side) was different thru the 3 years. However, based on what all you are saying they are all the same.
thanks alot for your help.
Pete
Re: 72 thru 74 cudas [Re: harborracer] #1223724
04/29/12 01:00 AM
04/29/12 01:00 AM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
if it has stripes on the side each year is different.
What was I thinking....
Re: 72 thru 74 cudas [Re: 72blubird] #1223725
04/29/12 01:03 AM
04/29/12 01:03 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I know the '72 is a one year only type stripe, but always thought the '73&4 was the same??
Re: 72 thru 74 cudas [Re: Sunroofcuda] #1223726
04/30/12 02:31 AM
04/30/12 02:31 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
72s are easy to tell apart from 73s and 74s. 72s have the bumpers close in to the body, like the 70s and 71s did, and they used the same thin chrome bumper guards that hang below the rear bumper like the 70s and 71s did. For 73s and 74s the bumpers stick out about 2 inches further out from the body front and back due to the "5 MPH Bumper" federal regulations, and they came with the big ugly rubber bumper guards that many people removed over the years. You can see those bumpers sticking out away from the body from a long way away.
You could tell the difference between a 73 and 74 if its got the "340-4 barrel" or "360-4 Barrel" emblem on the hood, since 73 was the last year for 340s and 360s were available in 74 only, but that also could have been changed out through the years, so it's not foolproof. Other than that, it's tough to tell the difference between a 73 and a 74 without looking at the numbers.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 72 thru 74 cudas [Re: BS27R1B] #1223727
04/30/12 05:26 AM
04/30/12 05:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
while I'll admit that the 71 Challenger and 71 Barracuda Grilles are the high water mark for both cars, the 72-74 Cuda grille looked much better than the same year Challengers.
Re: 72 thru 74 cudas [Re: Kern Dog] #1223728
04/30/12 09:54 AM
04/30/12 09:54 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
72's had hardback seats and the 73/74 had softback seats.
Re: 72 thru 74 cudas [Re: BS27R1B] #1223729
04/30/12 10:09 AM
04/30/12 10:09 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Unlike the 71 Cuda that looks like it was designed by an engineer putting every double sidded tape stick accessory possible out of the 1970 JC Whitney catalog.
Re: 72 thru 74 cudas [Re: TC@HP2] #1223730
04/30/12 10:33 AM
04/30/12 10:33 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 72 thru 74 cudas [Re: Kern Dog] #1223731
04/30/12 11:16 AM
04/30/12 11:16 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
'72 - '74 'Cuda grill looks good....challenger, not so much. From a strickly styling perspective, I think the '72 and up grill looks better than the '70. Instead of looking at the 5mph bumpers and the bumper guards as a big negative, I am reminded that they are 1000% better than what GM did to their cars to comply; we got lucky!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 72 thru 74 cudas [Re: DPelletier] #1223732
04/30/12 11:21 AM
04/30/12 11:21 AM
DPelletier Offline
DPelletier  Offline
vs.
Re: 72 thru 74 cudas [Re: DPelletier] #1223733
04/30/12 11:26 AM
04/30/12 11:26 AM
DPelletier Offline
DPelletier  Offline
vs.
anyhow, sorry for getting a little off topic.
Re: 72 thru 74 cudas [Re: DPelletier] #1223734
04/30/12 11:30 AM
04/30/12 11:30 AM
DPelletier Offline
DPelletier  Offline
My ugly '74 survivor;
