Re: Inexpensive header coatings? [Re: Montclaire] #1218730
04/20/12 10:12 AM
04/20/12 10:12 AM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
Probally the cheapest option is pot belly stove black if you just want Them to look not crusty,to get the best back yard job you can see if you soak them in caustic soda for 24 hrs pressure clean then bake in an oven to remove all traces of grease then blast and paint then bake.ive been doing cerama chrome coating for quite a while here in oz. The price you were quoted and what other guys have mentioned seems about right.Regarding the new headers already coated IMHO the coating that comes on any manufactures pipes are just to suck u in!It just crap.
Re: Inexpensive header coatings? [Re: Montclaire] #1218731
04/20/12 10:24 AM
04/20/12 10:24 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i used another paint product called RED HOT that is silver in color that i used on the exh extension and mufflers that has held up well.
Re: Inexpensive header coatings? [Re: Clanton] #1218732
04/20/12 11:26 AM
04/20/12 11:26 AM
K
Kiddart Offline
Kiddart  Offline
K
Mountclaire,
I just did my TTI headers a few weeks ago, I sand blasted them down just the outside, they were ceramic coated from TTI and did not stand up to well. After i blased them I bought VHT silica ceramic paint at the parts store. I did drivers side with that and the other side with a two part ceramic paint, both satin finish, they look identical, I baked them in a comercial oven for a few hours at 600 degrees. they look good and I am expecting them to last a while. My brother did his two years ago with the VHT and they still look as good as the day he did them. thats my two cents.
Thank you
Kiddart
Re: Inexpensive header coatings? [Re: MR_P_BODY] #1218733
04/20/12 01:20 PM
04/20/12 01:20 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Yeah, I can buy new for $250
Your not buying new headers that are ceramic coated
for $250
I'm thinking the same thing. New and painted maybe, but not new and ceramic coated. If they are really $275 for coated ones, then I'd seriously question the quality.
Without a doubt.... even a plain set of headers for
$275 I would REALLY wonder
The cheapest ceramic coated BBM headers on the market that I can find are the Summit brand, and they're currently $342- They are 1-7/8" primaries.
Re: Inexpensive header coatings? [Re: Montclaire] #1218734
04/20/12 03:25 PM
04/20/12 03:25 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
take the choke and buy a new pair that are coated...
Re: Inexpensive header coatings? [Re: smokinwoody] #1218735
04/20/12 10:36 PM
04/20/12 10:36 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
no way dude ...save your money ...try the por-15 black velvet.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Inexpensive header coatings? [Re: 69dart] #1218736
04/20/12 10:40 PM
04/20/12 10:40 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
I think the key is baking them, I'm going to try a local guy and see what he recommends. I don't have anything near big enough to fit them available to me.
Re: Inexpensive header coatings? [Re: Montclaire] #1218737
04/20/12 10:59 PM
04/20/12 10:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
there are 3 keys to a good finish. proper finish, part has to be super clean & baked at proper temp & time.
Re: Inexpensive header coatings? [Re: rickraw] #1218738
04/21/12 01:08 AM
04/21/12 01:08 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I had QC coatings do the header in my Jeep, I had to put a good size clearance dent in the header after the fact, Ball peen hammer wouldn't take off the coating! I would use them again in a heart beat. I thought the price was great also.
Re: Inexpensive header coatings? [Re: Joshs68] #1218739
04/21/12 01:22 AM
04/21/12 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
These are the set I made for my Rampage(W-5 heads)
thatQC did for me... I normally go silver but I have
to much shiney under the hood so I went black
Re: Inexpensive header coatings? [Re: MR_P_BODY] #1218740
04/21/12 01:50 AM
04/21/12 01:50 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I've used Por-15 black and silver and Black Velvet from Techline on headers and manifolds. Each is not 100% reliable BUT I like the fact I can touch it up as needed VS a coating.
I sandblast them (no glass bead) - clean them really good (don't touch them with you hands) hit them with a propane torch to boil out any grease oil and clean them again.
Spray product with a cheap touchup gun and partially cure them with a infrared or propane heater, then finish on the car. Por 15 will smear if just left to air dry.
Tried it once with a salamader heater but I had a reaction ( I assume from the kerosene)
