Your nice aluminum water pump/housing
#1218262
04/18/12 03:03 PM
04/18/12 03:03 PM
Posts: 5,923 Athens, Greece
Pyper70
Athens, Greece
Do you paint it engine color to blend in or leave it in its natural cast finish? Does leaving it unpainted allow the heat to radiate off of it faster?
The one I have in there now is the old cast iron one, does its job but I can hopefully drop my temperatures a little with this Mancini housing.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Your nice aluminum water pump/housing
[Re: AndyF]
#1218264
04/18/12 05:09 PM
04/18/12 05:09 PM
Pyper70
Athens, Greece
Well the intake manifold is jet hot coated...My RPM heads I was just going to leave bare casting....should be able to clean just fine with the 1000 miles she gets driven per year
[Re: Pyper70]
#1218265
04/18/12 05:25 PM
04/18/12 05:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Clear engine enamel.Dupli Color will yellow over time,but Plasti Kote and Rust-O-Leum engine clears work great.
[Re: Pyper70]
#1218272
04/18/12 11:51 PM
04/18/12 11:51 PM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
So....you use rattle can aluminum paint .....where you push the nozzle and nothing comes out?
Comes out just fine. You have to hold the can with the nozzle UP.
[Re: Pyper70]
#1218275
04/19/12 03:51 PM
04/19/12 03:51 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
IMO, you will find that the finish on the waterpump housing and it's subsequent ability to affect the efficiency of your cooling system is an order of magnitude below insignificant. Paint or don't based on what you want it to look like and/or maintenance issues. My vote is for paint. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: Ramrod39]
#1218280
04/20/12 02:23 AM
04/20/12 02:23 AM
Posts: 363 kentucky
roadrunner7020
kentucky
Ron - where does the hose connected to the breather cap go? What kind of breather is on the other valve cover and where is it connected?Quote:
possibly to the header evap
[Re: Pyper70]
#1218281
04/20/12 02:11 PM
04/20/12 02:11 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I use clear single stage polyurethane and add a touch of silver metallic...tough as nails, looks great, wipes clean like glass.
RIP Monte Smith
