Re: Will a 440 car motor drop right onto my 340 k-member? [Re: DAYCLONA] #1218070
04/17/12 11:46 PM
04/17/12 11:46 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
As for kickdown I may just run a manual valve body. Thanks for the replies.
Still need a K/D
Not with a FULL manual valve body, the Kick down is eliminated
I thought you did but maybe not?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218071
04/17/12 11:53 PM
04/17/12 11:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have ran a t/a valve body for years and it does away with the need for a kickdown. Do certain manual vb's require a kickdown? Because I do want low band apply this time around.
The only "manual" valve bodies that still require kick down activation are the aftermarket kits, like B&M's Transpak that allows the builder to select/choose during the rebuild a manual/automatic shift option to be retained, which retains the K/D, or build a full manual valve body set-up that eliminates the K/D
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: DAYCLONA] #1218072
04/17/12 11:56 PM
04/17/12 11:56 PM
moparmarks Offline
moparmarks  Offline
Thats good to know beings how I'm going with a full manual in my 440 Dart.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
