Will a 440 car motor drop right onto my 340 k-member? #1218050
04/17/12 11:00 PM
04/17/12 11:00 PM
junction city oregon
V
viperblue72 Offline OP
V
I have a 72 cuda, originally a 340 car. Will a 72 new yorker 440 drop right in place or are the motor mounts or k-frame different?
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218051
04/17/12 11:05 PM
04/17/12 11:05 PM
PA USA
flatiron Offline
flatiron  Offline
PA USA
K frame is the same. Motor mounts will be different
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218052
04/17/12 11:05 PM
04/17/12 11:05 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
Yes it will. I think you need 440 mounts for the E-Body which are easy to come by.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218053
04/17/12 11:05 PM
04/17/12 11:05 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep will fit right in there with your K and the C mounts. Will need a B oil pan though.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: Leadfoot] #1218054
04/17/12 11:06 PM
04/17/12 11:06 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
On second thought. Will the mounts from the New Yorker work? Anyone know?
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218055
04/17/12 11:07 PM
04/17/12 11:07 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
k-frames are the same, thinking you might have to change the brackets , not sure...
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparmarks] #1218056
04/17/12 11:07 PM
04/17/12 11:07 PM
moparmarks Offline
moparmarks  Offline
66-72 C's have the same mounts as the 66-72 B's and 70/1 E's
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: 70Challengerse] #1218057
04/17/12 11:08 PM
04/17/12 11:08 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
All you guys are quicker than me. Taken off the tree twice in one thread.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: Leadfoot] #1218058
04/17/12 11:09 PM
04/17/12 11:09 PM
moparmarks Offline
moparmarks  Offline
zoom zoom
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218059
04/17/12 11:12 PM
04/17/12 11:12 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes the 72 C body motor mounts will work, the C body oil pan will clear the K and suspension of the E you can use your stock Cuda transmission mount from the smblk, I'd recommend a new BBlk radiator, you could use the C body rad, but it would require redrilling some holes, you need to lengthen some wires on your stock harness, the dist. leads, coil leads and the water temp sender wire, the alternator leads are fine, if your 340 was 727 equipped, and your going to run a BB 727, all the E body 727 shift brackets will swap over to the BB 727....if the C body has the 1 pc kick down rod, it may interfere with the E body firewall,...you need to locate a 3 pc kickdown set up....get rid of the C body exhaust manifolds and use either B/E 70-1 B/RB manifolds, or headers
I've done this swap many times over the decades, C bodies were the engine donors of choice
Mike
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: DAYCLONA] #1218060
04/17/12 11:24 PM
04/17/12 11:24 PM
moparmarks Offline
moparmarks  Offline
C kickdown won't work but can use the 71/2B one piece kickdown.
I myself never had luck with the C pan. Center link rubbed against the pan but can be cleared.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: DAYCLONA] #1218061
04/17/12 11:31 PM
04/17/12 11:31 PM
Lebanon CT.
moparjoe4406 Offline
Joe the plumber
Joe the plumber
Lebanon CT.
I've done a few of those swaps in the 80's when you could get New Yorkers for a couple of hundred, and a 318 e body for about 800, the good old days...... you might also have to shorten the drive shaft,and the u joints might be different,if it has the 904.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparmarks] #1218062
04/17/12 11:32 PM
04/17/12 11:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually found the C body oil pans from 75 and up were an issue in the E/B chassis with the centerlink
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparmarks] #1218063
04/17/12 11:32 PM
04/17/12 11:32 PM
V
V
Wow thank you guys! I plan to use my 72 440 with an xe274 cam, 440source heads, and rpm intake. I will eventually get a nice set of headers, and go with a bigger motor. But for now I want to get it running. I still need wiring harnesses which I may just get new from year one. As for kickdown I may just run a manual valve body. Thanks for the replies.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: viperblue72] #1218064
04/17/12 11:34 PM
04/17/12 11:34 PM
moparmarks Offline
moparmarks  Offline
Still need a K/D
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparjoe4406] #1218065
04/17/12 11:35 PM
04/17/12 11:35 PM
V
V
I plan to use a bb 4x4 tranny with the sb tailshaft. Also I got a b-body dana for it. I don't yet have a driveshaft, so I will have to find one and have it made to the right length.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: DAYCLONA] #1218066
04/17/12 11:37 PM
04/17/12 11:37 PM
moparmarks Offline
moparmarks  Offline
Just dropped a 71C into a 70 Challenger and the link rubbed. Not too bad and was an easy fix.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparjoe4406] #1218067
04/17/12 11:40 PM
04/17/12 11:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
...the OP didn't state the type of tranny, but if it's a 340 car, it will be either 727 or 4 spd, either case it will be an 8 3/4 rear, so his shaft will fit the BB 727 if so equipped....usually the 318 cars were 904 equipped and 7 1/4 rear, so the shaft was longer, and ran smaller u joints
Mike
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparmarks] #1218068
04/17/12 11:40 PM
04/17/12 11:40 PM
V
V
Still need a K/D
I have ran a t/a valve body for years and it does away with the need for a kickdown. Do certain manual vb's require a kickdown? Because I do want low band apply this time around.
Re: Will a 440 car motor drop right onto my 340 k-member? [Re: moparmarks] #1218069
04/17/12 11:44 PM
04/17/12 11:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Still need a K/D
Not with a FULL manual valve body, the Kick down is eliminated
