Car shuts off when it warms up #1216304
04/15/12 02:42 PM
04/15/12 02:42 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
Just finished a car with someone, and it starts fine then shuts down when it warms up a bit.
Where do we start?
Re: Car shuts off when it warms up [Re: DANA60] #1216305
04/15/12 02:49 PM
04/15/12 02:49 PM
Kirkland, Washington
Pacnorthcuda Offline
Determine if its electrical (likely) or fuel (less likely)
Re: Car shuts off when it warms up [Re: Pacnorthcuda] #1216306
04/15/12 03:51 PM
04/15/12 03:51 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Choke?
I have mechanical Aptitude.
I can screw up anything.
Re: Car shuts off when it warms up [Re: bboogieart] #1216307
04/15/12 03:59 PM
04/15/12 03:59 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
overloading your fusible link?.....when it cools down...it resets and you can start it again? Must have a leak somewhere in the wiring.
possibly
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Car shuts off when it warms up [Re: Pyper70] #1216308
04/15/12 06:01 PM
04/15/12 06:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If it was the old Lean Burn system, that would be my first thought. Second thought would be the coil. Really a little more info like year and engine would help.
Re: Car shuts off when it warms up [Re: 6PakBee] #1216309
04/15/12 07:33 PM
04/15/12 07:33 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
70 Challenger, 383, just helped him put it all together. He installed Mopar elect ign. Not choke, but the coil sounds like a maybe.
Re: Car shuts off when it warms up [Re: DANA60] #1216310
04/15/12 09:34 PM
04/15/12 09:34 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
When it shuts off, will it restart? Have you confirmed whether spark is present? I just went thru something similar and last evening found the root cause to a an intermittent connector to the distributor. Apparently the thermal expansion as the motor got up to temp, combined with the vibration of the motor running would cause the connection to open, killing the pulses from the distributor to the ignition box.
Re: Car shuts off when it warms up [Re: davenc] #1216311
04/15/12 09:47 PM
04/15/12 09:47 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
I just went through this. Mine would start and run fine for 20 minutes then die at idle. It would start right back up but die if I put it in gear. Let it cool down and repeat.
I replaced the coil and it fixed the problem.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: Car shuts off when it warms up [Re: TinCuda] #1216312
04/15/12 11:45 PM
04/15/12 11:45 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
if its not an ignition problem (orange box?) than dont rule out the carb. I had problems with the floats on my old Holley and they would routinely stick and flood itself out after some spirited driving.
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: Car shuts off when it warms up [Re: RangerDan440] #1216313
04/16/12 12:50 AM
04/16/12 12:50 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
If it has electronic ignition check the pick up in the distributor. I had one go bad on me and it was doing exactly what your talking about.
Re: Car shuts off when it warms up [Re: GreenGlow] #1216314
04/16/12 01:25 AM
04/16/12 01:25 AM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
+1
Hall effect in the distributor is a common problem with FWD Mopars and I've had similar symptoms when they went bad.
