Re: Car shuts off when it warms up
[Re: bboogieart]
#1216307
04/15/12 03:59 PM
04/15/12 03:59 PM
Posts: 5,903 Athens, Greece
Pyper70
Athens, Greece
overloading your fusible link?.....when it cools down...it resets and you can start it again? Must have a leak somewhere in the wiring.
possibly
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1216308
04/15/12 06:01 PM
04/15/12 06:01 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
If it was the old Lean Burn system, that would be my first thought. Second thought would be the coil. Really a little more info like year and engine would help.
[Re: davenc]
#1216311
04/15/12 09:47 PM
04/15/12 09:47 PM
Posts: 297 Oklahoma
TinCuda
Oklahoma
I just went through this. Mine would start and run fine for 20 minutes then die at idle. It would start right back up but die if I put it in gear. Let it cool down and repeat.
I replaced the coil and it fixed the problem.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: TinCuda]
#1216312
04/15/12 11:45 PM
04/15/12 11:45 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
if its not an ignition problem (orange box?) than dont rule out the carb. I had problems with the floats on my old Holley and they would routinely stick and flood itself out after some spirited driving.
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: GreenGlow]
#1216314
04/16/12 01:25 AM
04/16/12 01:25 AM
Posts: 173 Milano, Italia
FK5
Milano, Italia
If it has electronic ignition check the pick up in the distributor. I had one go bad on me and it was doing exactly what your talking about.
+1 Hall effect in the distributor is a common problem with FWD Mopars and I've had similar symptoms when they went bad.
