LA rockers #1215863
04/14/12 10:56 PM
04/14/12 10:56 PM
West Tennessee
rbstroker Offline OP
West Tennessee
I understand that the stock stamped steel rocker arms used on hydraulic cammed LA engines very seldom are actually a 1.5:1 ratio. Does anybody make a stock type stamped steel rocker that is a true 1.5 or even 1.6?
Re: LA rockers [Re: rbstroker] #1215864
04/15/12 12:40 AM
04/15/12 12:40 AM
Locomotion Offline
Locomotion  Offline
Never heard of any correct or higher ratio stamped rockers for Mopar. A little ratio is also lost through the different angles in the lifter/pushrod/rocker geometry.
Re: LA rockers [Re: Locomotion] #1215865
04/15/12 09:02 AM
04/15/12 09:02 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
This is a quote out of one of the Mopar magazines from a while back. Yes it is true what was said above about loosing ratio in the angles of the push rod. The amount of change is surprising.
