engine dies when key is released
#1215842
04/14/12 10:52 PM
04/14/12 10:52 PM
Posts: 28,096 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My 72 Imperial was running fine before we pulled the instrument panel. When the panel was out the engine would die when the key was released. I've reinstalled the dash and the engine still dies when the key is released.
Andrewh and I pulled the cluster to clean it and get the fuel gauge working. He found some random wire under the hood that was dangling and not plugged into the bulkhead connector. Naturally, he plugged it back in. He used the wiring diagrams to locate it's proper place. He also fiddled with the ballast resistor but I made sure it was plugged in.
Is there anything related to the instrument panel that would cause this problem? The steering column was not unplugged and I tried to reconnect all the ground wires.
Re: engine dies when key is released
[Re: DARTH V8Я]
#1215844
04/14/12 11:13 PM
04/14/12 11:13 PM
feets
Senior Management
Senior Management
Irving, TX
The ballast resistor would be the first thing I'd look at. This one is less than a year old. The kicker is that it worked before we removed the instrument cluster a couple weeks ago. I was just going over the wiring diagrams and didn't see any obvious culprits but I don't know which wire in the bulkhead Andy messed with.
I think I've got a spare ballast resistor and I was about to try it.
[Re: feets]
#1215845
04/14/12 11:28 PM
04/14/12 11:28 PM
feets
Senior Management
Senior Management
Irving, TX
The ballast resistor tested the same as the new part I had. I swapped the resistors and it still died when I released the key.
[Re: stumpy]
#1215847
04/14/12 11:50 PM
04/14/12 11:50 PM
feets
Senior Management
Senior Management
Irving, TX
I called him but the wifegod intercepted. Andy is babyfied and unable to talk. Perhaps he'll call me tomorrow.
The good news is that the fuel gauge seems to work. Kinda. I've got about 3/4 tank and the gauge reads a touch under 1/2.
I'll have to check the wires for voltage in the morning. We're supposed to get ugly storms so it may have to wait until later in the day.
[Re: feets]
#1215848
04/14/12 11:57 PM
04/14/12 11:57 PM
Posts: 3,933 Oregon
hooziewhatsit
Yep, what Stumpy said.
I'd disconnect the line to the starter, then use a DMM on ign1 and ign2 at the ballast while playing with the key to see which voltage isn't there when it should be.
Then it's just tracing it back to find the break, which could even be the ignition switch itself.
[Re: feets]
#1215853
04/15/12 08:04 AM
04/15/12 08:04 AM
Posts: 21,123 Niles , Ohio
therocks
Niles , Ohio
Look at the big connector on the column also.72 thru I believe 75s had a problem with them getting hot and losing contact.My 73 would lose power.I pulled the connector apart cleaned it and replaced 2 pins and had no problems after that.Rocky
Chrysler Firepower
