hi there
my 77 dodge street van 318 auto , has an edelbrock sp2p intake and carb !!
just started it for the first time this year and it has a miss when in gear and is really sluggish
so i did a compression check all is good 125 to 130 psi , plugs look okay , checked the timing it was around 10 !!! so i advanced the timing and the missing went away motor picked right up
runs a lot better but cant see the mark on the balancer at all !! climbed under van and checked timing and the mark on the balancer was at around 10 oclock lookin from the front
so i have no idea
could the timing chain have jumped a gear ??? thanks mike
