Re: 400 SMALL BLOCK!!?
[Re: MoparGary7272]
#1213897
04/11/12 10:27 PM
04/11/12 10:27 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Are you looking for something like a junkyard engine/tranny, or want something built? Where in NY are you located?
RIP Monte Smith
[Re: CompWedgeEngines]
#1213898
04/11/12 10:48 PM
04/11/12 10:48 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
if he's too stupid to know what the motor is you don't want to buy it if he built it.
[Re: Supercuda]
#1213899
04/11/12 11:17 PM
04/11/12 11:17 PM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
The Ford 400M was a small block. It gets called a big block alot, but it only shared a bellhousing pattern with the 460. Tell this clown that the CI was never cast into the side of the block. It is stamped under the driver's side head.
[Re: zrxkawboy]
#1213901
04/11/12 11:26 PM
04/11/12 11:26 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
10 to 1 its a Ford 400 engine.
When it takes more than a sweet mullet to prove you rule at the trailer park..
#1213902
04/12/12 09:58 AM
04/12/12 09:58 AM
Posts: 99 NY
MoparGary7272
NY
im doing a super six to An eight cylinder swap... The super six spun all but one bearing due to the oil pumped being clogged... I was going to toss it and throw a standard bore motor in her... Id rather not have a mysterious built up motor cuz I want to drive the car knowing what's in it lol.... Im near Albany ny ...
[Re: MoparGary7272]
#1213904
04/12/12 10:57 AM
04/12/12 10:57 AM
DARTH V8Я
Its a TRAP!
So wheres the pics of this mythical beast?
[Re: Rug_Trucker]
#1213912
04/13/12 12:00 PM
04/13/12 12:00 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
My guess, being it was in an early 70's comercial truck, it's the 400 big block, and the seller has low deck confused with small block. It's a big block but not a raised deck big block. Non mopar folk might get this mixed-up.
I have mechanical Aptitude. I can screw up anything.
[Re: Supercuda]
#1213913
04/13/12 12:34 PM
04/13/12 12:34 PM
Posts: 480 Texas
racer_amx
Texas
+1
[Re: DARTH V8Я]
#1213914
04/13/12 12:50 PM
04/13/12 12:50 PM
RapidRobert
What Ice Eagle said it's time for a pic
