Page 3 of 4 1 2 3 4
Re: A833 tricks and modifications [Re: mshred] #1213368
04/11/12 08:19 PM
04/11/12 08:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I REALLY don't think ATF is a good lube for any 833 being used for anything but mild street use
If you need something lighter for cold weather use just get some straight 30 wt. motor oil and mix it 50-50 with 75-90 gear oil.
Gus
64 Plymouth Savoy
Dana 60
Re: A833 tricks and modifications [Re: fourgearsavoy] #1213369
04/11/12 08:21 PM
04/11/12 08:21 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Gus
Some say ATF is better, others say gear oil lol...I wasn't running the ATF because of climate- its warm enough here in the summer to run gear oil, and even if it takes longer to warm up, I don't mind. I tried the ATF and feel like if I go to the gear oil it just might be a little better for lubrication...mind you, there are quite a few threads on here with this debate, seems like either or works for people, just a matter which one someone wants to use
Re: A833 tricks and modifications [Re: mshred] #1213370
04/11/12 09:34 PM
04/11/12 09:34 PM
Truckville, the capital of NY
85_Ram_4speed Offline
As far as fluid, I have had excellent luck mixing 1 qt of ATF and fill the rest with 80w90 gear oil. It seems to be a good compromise. You can always fine tune the ratio for your liking though. I have tried straight runs of both and they both had shifting issues. So i just combined them.
Outcast Dodge guy.
Re: A833 tricks and modifications [Re: mshred] #1213371
04/11/12 09:43 PM
04/11/12 09:43 PM
Rittman Ohio
Rittman Ohio
I have had enough of these trannys apart to know what to use and what not to use.I have seen cluster pins and gears galled and flaked from ATF but gear oil filled transmissions always look better inside
Gus
64 Plymouth Savoy
Dana 60
Re: A833 tricks and modifications [Re: fourgearsavoy] #1213372
04/11/12 10:22 PM
04/11/12 10:22 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
The Liberty side cover mod and steel forks are a cheap and worth while modification that really doesn't affect anything else
I really think you should faceplate third and fourth gear and leave first and second alone for a street box
A good shifter and linkage is the key to clean shifts,for an H-pattern shifter get the Hurst Super Shifter III, for a V-gate go for the Long shifter and fab up your own linkage with heim joints and steel tube shift rods
Gus
I have Gus's old long shifter and modified cover for sale............
Re: A833 tricks and modifications [Re: mshred] #1213373
04/11/12 11:21 PM
04/11/12 11:21 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This thread really blew up! I like it! Hopefully there are some more tricks that come out of the woodwork
Unfortunately, short of building a crashbox there aren't a whole lot of mods to improve the box other than what's been posted about the forks, detent mods and shift rods.
And as much as I'd like to take credit for the detent mods, the old Chrysler boys were doing that way back in the '60's and it was published in a race bulletin.
Re: A833 tricks and modifications [Re: 10.90 Racer] #1213374
04/12/12 04:03 AM
04/12/12 04:03 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Gus
Pics???
Re: A833 tricks and modifications [Re: mshred] #1213375
04/12/12 08:55 AM
04/12/12 08:55 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
hey guys,
hopefully this hasn't been covered here before and isn't a naive question. I finally picked up a backup 23 spline box for my car, and right now both are bone stock but in great shape. I beat on my last box last year to the times in my sig with no real issues except sometimes a grinding on the 2-3 shift ( i think clutch adjustment and my technique were to blame there)
This year im planning to run high/mid 11's, and faster on spray. Besides clutch stuff, what tricks are out there to help the transmission live longer, shift better, etc.? I know there is only so much that can be done, and I know its only a 23 spline, but does anyone who has raced or still races these things have any tips or suggestions?
I still street drive mine so all out face plating/pro shifting is out of the picture until I am having trouble at higher rpms. Just looking for ways to get extra life or performance out of it if I can since they are both apart right now and getting back together for the beginning of my season
Did you check the air gap between the flywheel and the disc with the clutch pedal pushed to the floor? If you don't have enough gap then it will be tough power shift. Gap is slightly different for different pressure plate styles but .050" is a good number to shoot for. Some A-body pedals like the ones used in 340/360 cars have a diffent pedal with a longer lever that move the bellcrank slightly more for more air gap so using a 318 or /6 combined with high pressure plate loads may deflect the linkage just enough to not allow enough release for a good power shift. Also way too much air gap will cause problems too. Bottom line of all this mumbo jumbo is check the air gap and correct it if needed.
Re: A833 tricks and modifications [Re: 446acuda] #1213376
04/12/12 09:53 AM
04/12/12 09:53 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
hey guys,
I accually changed my ratio off a tech article in mopar muscle. I also made all the z bar linkage with tubes and heim joints, thats been covered on here before. As for the other pointers, it was basic tear down, inspection, and tech stuff like that. He told me about what they accually do to the side covers, and that kind of thing. Just give him a call, he is a very cool giy to shoot the breeze with.
Re: A833 tricks and modifications [Re: Moparnut426] #1213377
04/12/12 02:12 PM
04/12/12 02:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Does going with the newer style syncro's provide any added benefit?
Re: A833 tricks and modifications [Re: astjp2] #1213378
04/12/12 02:47 PM
04/12/12 02:47 PM
MI
68shifter Offline
68shifter  Offline
MI
astjp2 - In the other thread you mentioned to cryo gearsets. That bottom cluster thats broke is one of the Taiwan units. It has been cryo'd and mikronited. I have/had 2 complete 18 splines faceplated with everything internal cryo'd and mikronited. Pushing the limits of what the trans can handle it doesnt help, but for added life and dcereased friction it is beneficial but cost vs benefit?
Here are some old things I have from Liberty...kinda neat
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: A833 tricks and modifications [Re: astjp2] #1213379
04/12/12 03:05 PM
04/12/12 03:05 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
The new style blocker rings are less likely to crack since there is no sharp corner for a crack to start like the old style has and the syncro struts in the new style synchros hold up better.
Re: A833 tricks and modifications [Re: 446acuda] #1213380
04/12/12 03:42 PM
04/12/12 03:42 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok so Passon list the NOS newer Syncro's for 249.00, Brewers has what I assume is aftermarket ones for 169.00 and Zumbrota has them for 192.00. Is it worth getting the NOS ones?
Re: A833 tricks and modifications [Re: astjp2] #1213381
04/13/12 09:44 PM
04/13/12 09:44 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I tore down an A-body tranny that I had laying around, syncro's looked good so I am going to use them. Are all the 1st gears the same? The steel shift forks were pretty worn but the brass ones I have looked like new. One slider had some chipped teeth so I swapped it with one with just a little wear. Now I just need to get a B-body non trunion main shaft. Tim
Re: A833 tricks and modifications [Re: astjp2] #1213382
04/13/12 10:01 PM
04/13/12 10:01 PM
MI
68shifter Offline
68shifter  Offline
MI
Passon has main shafts, used and I believe new. If you dont see any listed on his site give him a call he has alot of stuff laying around. Probably the same for brewers as well. Good luck.
Re: A833 tricks and modifications [Re: astjp2] #1213383
04/13/12 11:01 PM
04/13/12 11:01 PM
Rittman Ohio
Rittman Ohio
I just sent Jamie a perfect B/E-body mainshaft in trade for some other parts so I know he has at least one
Gus
64 Plymouth Savoy
Dana 60
Re: A833 tricks and modifications [Re: mshred] #1213384
04/14/12 01:09 PM
04/14/12 01:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I was hoping Wayne or Jamie would provide some input on this, I am going to convert an A-body overdrive into a B-body, I only need a few hundred in parts and then I will use it as my cruising tranny until I can afford Jamie's overdive or an 18 spline. I sure hope it will hold up behind a 572 hemi in a B-body....Tim
Re: A833 tricks and modifications [Re: astjp2] #1213385
04/14/12 02:15 PM
04/14/12 02:15 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Sure as long you plug the main jets and only ise the idle system
Re: A833 tricks and modifications [Re: fourgearsavoy] #1213386
04/14/12 03:16 PM
04/14/12 03:16 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Gus
Gus, what weight/type gear lube do you recommend?
383, Hemi 4-Speed, AlterKtion, D60
Re: A833 tricks and modifications [Re: Crazy68Dart] #1213387
04/14/12 06:50 PM
04/14/12 06:50 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
did the detent mod that stanton posted last night to two different covers. Did one at a time to compare, and yes, there is a difference even just moving the detents by hand
In the process I was also able to find that pin between the two detent balls in my sidecover was missing this entire time I was running the transmission good thing I finally got this side cover apart
Page 3 of 4 1 2 3 4
