Page 2 of 4 1 2 3 4
Re: A833 tricks and modifications [Re: F1Scamp] #1213348
04/11/12 09:38 AM
04/11/12 09:38 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Cut off the "nubs" from the steel forks to allow installation in the early ball-detent side cover.
See pic - use cut-off wheel to trim off end flush with larger shaft diameter that slides into the side cover.
Re: A833 tricks and modifications [Re: DusterW2] #1213349
04/11/12 09:40 AM
04/11/12 09:40 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
After pic -
Re: A833 tricks and modifications [Re: DusterW2] #1213350
04/11/12 11:05 AM
04/11/12 11:05 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here's what you want to do ...
use the steel forks - the brass one's have a tendency to snap off at the shaft. Since the steel forks only came on the slider style side covers they are made with an additional smaller shaft on the ends - you just cut those off.
on the detents you want to round off the sharp edge off on both sides of the neutral position and do the same on the leading edge on the 1, 2, 3 and 4. This is so the detent ball will slide more easily when you shift. DO NOT grind the edge where the ball stops!
The thing will shift so smooth you won't believe it.
Re: A833 tricks and modifications [Re: Stanton] #1213351
04/11/12 11:24 AM
04/11/12 11:24 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I'll have to try that on my spare "stock" transmission. See if it truely shifts easier. Sounds like it would work.
Thanks,
Re: A833 tricks and modifications [Re: LAR_414] #1213352
04/11/12 12:05 PM
04/11/12 12:05 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Do nothing.
I shift a STOCK 833 to low 11's on slicks...and drive it a ton on the street. I power shift it at around 6,200rpm.
Might seem like a real dumb question, Ive never power shifted my 833, too afraid to break stuff, so is this really how it sounds, you dont clutch at all, just back off throttle a touch and pound it into gear?
Seems like a lof of damage could happen if the syncros werent cut...
Kasey
Re: A833 tricks and modifications [Re: Stanton] #1213353
04/11/12 12:07 PM
04/11/12 12:07 PM
Moparnut426 Offline
Moparnut426  Offline
Stanton, Do you have any pictures of this mod, and where/what to cut grind? Im thinking of doing some mods to mine.
Kasey
Re: A833 tricks and modifications [Re: Moparnut426] #1213354
04/11/12 12:36 PM
04/11/12 12:36 PM
LAR_414 Offline
LAR_414  Offline
Switch feet!
Don't lift off the gas. You have to clutch it.
Having a rev limiter helps when the engine goes "no load" for a split second at WOT!
It's way too much fun seeing the shift light come on and just pushing the clutch in and stiring the stick to the next gear, while not lifting off the gas at all. HITS HARD!
Re: A833 tricks and modifications [Re: LAR_414] #1213355
04/11/12 02:01 PM
04/11/12 02:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Unfortunately no pics but here's a "rough" sketch.
Re: A833 tricks and modifications [Re: Stanton] #1213356
04/11/12 03:25 PM
04/11/12 03:25 PM
MI
68shifter Offline
68shifter  Offline
MI
Here are a couple pics of the side cover stuff. You'll notice one fork, 3/4, says liberty on it. Look at it in the comparison as it is slightly different, used that with the faceplate setup stuff.
Hope these help.
Two stock ones, as you can see the affore mentioned nub has already been shortened on the one.
The knock in seal, they are green scotseals. You just have to be careful that the shaft doesnt tear the lip as you push them through.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: A833 tricks and modifications [Re: 68shifter] #1213357
04/11/12 03:38 PM
04/11/12 03:38 PM
LAR_414 Offline
LAR_414  Offline
Thanks for the Pics Andre!
So what is the difference between the Liberty Steel fork and the OEM Steel fork?
BTW, I've got brass ones and so does my dad. We've never ever broken a fork....yet.
Re: A833 tricks and modifications [Re: LAR_414] #1213358
04/11/12 03:49 PM
04/11/12 03:49 PM
MI
68shifter Offline
68shifter  Offline
MI
Brass was just more "apt" to break. I have never run them just out of fear. But you and your dad run damn hard so if there still there well...I dont have a good answer.
The liberty fork has a thick flange on one side vs a shallower flange on both for the factory piece. The face plate slider is also much "bigger" in diameter than a pro shift setup so you dont have the room on the slider side like factory.
Re: A833 tricks and modifications [Re: Stanton] #1213359
04/11/12 04:04 PM
04/11/12 04:04 PM
Moparnut426 Offline
Moparnut426  Offline
I just sopke with Paul at liberty, and I have to say he is one of the most helpfull guys I have ever talked to. He even sent me a cell phone picture of a tool he made to push the reverse shaft out of the case to replace that pesky O ring.
80 bucks is all he charges to do that HD kit to the side cover, and he gave me a few other "pointer"
Great guy!!
Re: A833 tricks and modifications [Re: Moparnut426] #1213360
04/11/12 06:26 PM
04/11/12 06:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A real simple tool to push out the reverse shaft can be made as follows:
take a piece of 5/8" cold rolled rod about 12" long (the size of the small end of the reverse shaft)
measure the distance from the front of the reverse shaft to the front of the side cover opening
heat the cold rolled just short of the above length and put a 90* bend in it - allow to cool
you now have an "L" shaped "lever". Put it in the case so one end contacts the reverse shaft and the other is against the front of the side cover opening. Using it as a lever, gently tap the portion of the lever that's sticking out of the case and the reverse shaft will pop right out - they aren't in very tight, just a [Edited by Moparts - Family Friendly Site - Keep it clean] to get out without a "tool".
Re: A833 tricks and modifications [Re: Stanton] #1213361
04/11/12 06:29 PM
04/11/12 06:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Aw c'mom, what's wrong with the word b*gger ?!?!?!?
Re: A833 tricks and modifications [Re: Stanton] #1213362
04/11/12 07:12 PM
04/11/12 07:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Liberty also told me that the Korean Hemi gear sets were just fine, they also thought that cryogenically treating them was a bonus. Tim
Re: A833 tricks and modifications [Re: astjp2] #1213363
04/11/12 07:43 PM
04/11/12 07:43 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The Liberty side cover mod and steel forks are a cheap and worth while modification that really doesn't affect anything else
I really think you should faceplate third and fourth gear and leave first and second alone for a street box
A good shifter and linkage is the key to clean shifts,for an H-pattern shifter get the Hurst Super Shifter III, for a V-gate go for the Long shifter and fab up your own linkage with heim joints and steel tube shift rods
Gus
64 Plymouth Savoy
Dana 60
Re: A833 tricks and modifications [Re: Stanton] #1213364
04/11/12 08:02 PM
04/11/12 08:02 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
This is a great idea! Has anyone else done anything like this before? I've never really taken a good look at the edges of those detents to see how sharp they really are
Re: A833 tricks and modifications [Re: 68shifter] #1213365
04/11/12 08:05 PM
04/11/12 08:05 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hope these help.
Thanks for the pics Andre! Do you know if Liberty did the smoothing mod on your detents on the sidecover as well? The HD mods sound good, but gotta see if I can swing the cash right now. I wonder how much those liberty steel forks are- if im gonna spend money on forks, I'd rather get theirs if they are similar in price
Re: A833 tricks and modifications [Re: Moparnut426] #1213366
04/11/12 08:06 PM
04/11/12 08:06 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Great guy!!
Did he say how long it would take to send the cover and get it back? I've always been kinda leary about them since I know they say a certain time but you don't see your stuff back for months.
And what other "pointers" did he give you...care to share?
Re: A833 tricks and modifications [Re: Cab_Burge] #1213367
04/11/12 08:09 PM
04/11/12 08:09 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
My experience withe the brass fork is that the shaft will sheer off of the fork at the most inopportune time.
Been there, done that Get the steel forks and cut the nubs off and use them in the early cover OP, what fluids are you suing in your boxes? If not straight ATF try that
I actually planned on using some form of gear oil this year. I used Castrol Type F ATF. I thought that I could benefit though from the extra thickness of some 75W90 weight stuff for lubrication. I figure once its warm it should perform just like the ATF
Unless there is an ATF brand that works really well? I tried synchromesh last year and my trans grinded on every shift with it, even at lower speeds.
This thread really blew up! I like it! Hopefully there are some more tricks that come out of the woodwork
Page 2 of 4 1 2 3 4
