Page 1 of 4 1 2 3 4
A833 tricks and modifications #1213328
04/10/12 12:47 AM
04/10/12 12:47 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys,
hopefully this hasn't been covered here before and isn't a naive question. I finally picked up a backup 23 spline box for my car, and right now both are bone stock but in great shape. I beat on my last box last year to the times in my sig with no real issues except sometimes a grinding on the 2-3 shift ( i think clutch adjustment and my technique were to blame there)
This year im planning to run high/mid 11's, and faster on spray. Besides clutch stuff, what tricks are out there to help the transmission live longer, shift better, etc.? I know there is only so much that can be done, and I know its only a 23 spline, but does anyone who has raced or still races these things have any tips or suggestions?
I still street drive mine so all out face plating/pro shifting is out of the picture until I am having trouble at higher rpms. Just looking for ways to get extra life or performance out of it if I can since they are both apart right now and getting back together for the beginning of my season
Re: A833 tricks and modifications [Re: mshred] #1213329
04/10/12 01:24 AM
04/10/12 01:24 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There is a 307 bearing that has more balls than a standard bearing. I am curious on this topic since I have to build a tranny for my Charger...Tim
Re: A833 tricks and modifications [Re: mshred] #1213330
04/10/12 01:26 AM
04/10/12 01:26 AM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
You can "slick-shift" prep the trans by removing the brass syncro rings and grinding every 2nd tooth off the syncro hub, as well as every 2nd tooth off the inside of the syncro slider. There were some magazine articles back in the 70s detailing how to do it. The car would become marginally streetable, you have to double-clutch when shifting to keep from "grinding" the gears. I used to race 4-speeds, and did a couple transmissions myself, it really did make them shift quicker/easier.
Re: A833 tricks and modifications [Re: reknapp52] #1213331
04/10/12 02:37 AM
04/10/12 02:37 AM
sweden
sshemi Offline
sshemi  Offline
sweden
You dont have to remove the sync stop rings, take away every other tooth on them too, that way you dont have to double clutch.
Steel shiftforks should be used.
As long as you dont turn high rpms thats all that is needed.
Re: A833 tricks and modifications [Re: sshemi] #1213332
04/10/12 02:50 AM
04/10/12 02:50 AM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
I'm sure you have heard it....... but the key is in the clutch.....
Re: A833 tricks and modifications [Re: 10.90 Racer] #1213333
04/10/12 10:29 AM
04/10/12 10:29 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Do nothing.
I shift a STOCK 833 to low 11's on slicks...and drive it a ton on the street. I power shift it at around 6,200rpm.
Re: A833 tricks and modifications [Re: LAR_414] #1213334
04/10/12 03:31 PM
04/10/12 03:31 PM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
I agree--in an 11-second car a bone-stock trans in good repair should work just fine. As ETs get lower and RPMs increase, you will probably want to make some changes.
Re: A833 tricks and modifications [Re: astjp2] #1213335
04/10/12 11:26 PM
04/10/12 11:26 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I have heard others mention these and may just end up checking them out for one of my boxes that seemed to have quite a bit of input shaft slop
They are costly though from what I have read...about 100 bucks as opposed to the Chinese bearings at 20 bucks
Re: A833 tricks and modifications [Re: sshemi] #1213336
04/10/12 11:29 PM
04/10/12 11:29 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
I have heard the recommendation of steel forks before...im assuming that they are more bend resistant than the bronze ones?
I have also heard of the different slick shift methods, although this is a street box so a full on slick shift box would definitely not work out. I have thought about the halfway, keeping the synchro rings in. Going to be shifting this thing at around 6600-6700rpms this year, so we'll just have to see how much the box likes (or hates ) going into gear that high. Whatever I do, it needs to be able to hold up to street miles and not wear out super quickly
Re: A833 tricks and modifications [Re: 10.90 Racer] #1213337
04/10/12 11:30 PM
04/10/12 11:30 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
yup, I think one too many times...like my original post, was looking for stuff other than clutch tuning that helps. As much as I'd love to spring for an adjustable, its out of my budget, and definitely out of the realm of street driving that I do on this thing
Re: A833 tricks and modifications [Re: LAR_414] #1213338
04/10/12 11:31 PM
04/10/12 11:31 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Do nothing.
Im hoping my experience will be similar to yours...and that my increased shift rpms won't change that too much
Re: A833 tricks and modifications [Re: mshred] #1213339
04/10/12 11:36 PM
04/10/12 11:36 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Not to hijack this thread, but I am in a similar situation. I have 2 boxes, with 2 different shift fork setups.
Either of these better than the other?
First one:
Second one:
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: A833 tricks and modifications [Re: F1Scamp] #1213340
04/10/12 11:42 PM
04/10/12 11:42 PM
MI
68shifter Offline
68shifter  Offline
MI
F1, I like the steel fork in the bottom, but see the other fork isn't. Try to find another steel if possible. Inside of that trans looks good.
When it comes to the side covers I would highly recommend sending them to Liberty for the HD modifications. They incorporate a knock in seal so you don't have to rely on the fork o-ring, install 3/8 studs on the linkage side as the factory 5/16 will beat back the edge quick causing linkage slop. Last couple I had done were 100-150 bucks pending on what I had them do.
Good luck.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: A833 tricks and modifications [Re: 68shifter] #1213341
04/10/12 11:49 PM
04/10/12 11:49 PM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Yeah I was pretty happy with my 100 investment in that trans. Especially after I opened the original trans up to find all the gears are pitted pretty badly.
Thanks!
Re: A833 tricks and modifications [Re: F1Scamp] #1213342
04/10/12 11:54 PM
04/10/12 11:54 PM
MI
68shifter Offline
68shifter  Offline
MI
Let me know if you can't find a fork I've got a few laying around. PM if you need.
If I get a chance I'll take a pic of the hd cover tomorrow.
Andre
Re: A833 tricks and modifications [Re: 68shifter] #1213343
04/11/12 12:00 AM
04/11/12 12:00 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Andre
Hey Andre,
if you could post a pic of that cover it would be great! What is the benefit of the steel forks? less prone to bending/breaking? Both of my transmissions are currently brass forks like in the first picture above
thanks!
Re: A833 tricks and modifications [Re: mshred] #1213344
04/11/12 12:13 AM
04/11/12 12:13 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
My experience withe the brass fork is that the shaft will sheer off of the fork at the most inopportune time.
Getting old just means you were smarter than some and luckier than others.
Re: A833 tricks and modifications [Re: dannysbee] #1213345
04/11/12 02:23 AM
04/11/12 02:23 AM
Cab_Burge Online work
Cab_Burge  Online Work
Been there, done that Get the steel forks and cut the nubs off and use them in the early cover OP, what fluids are you suing in your boxes? If not straight ATF try that
Re: A833 tricks and modifications [Re: Cab_Burge] #1213346
04/11/12 08:56 AM
04/11/12 08:56 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Cut the nubs off? The ends of the shift forks? What does that do?
Re: A833 tricks and modifications [Re: F1Scamp] #1213347
04/11/12 09:17 AM
04/11/12 09:17 AM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
The later transmissions with the steel forks also had a "scissor" type system to hold the forks in whatever gear you were driving in. Earlier transmissions with the brass forks used spring-loaded detent balls to accomplish that. The detent-ball system was preferred for racing applications, so to use the steel forks in the detent-ball cover, the little "nubs" that engaged the "scissor" had to be cut off (I think to clear the cover). That's from memory, haven't been inside on of those since the early 80s.
Page 1 of 4 1 2 3 4
