Hydraulic roller cam package for 400 BB #1212593
04/09/12 11:10 AM
04/09/12 11:10 AM
Finally a HUSKER again
Moparnut426 Offline OP
Im rebuilding a 400 BB for a customer and he wants a hydraulic roller cam so he dosnt have to add crap to the oil, and wants the added benefits of a roller cam. I cant seem to find a package for the retro fit. Ive looked on summit, jegs, comp, and cranes web sites. I see howards makes a cam, havent seen a package deal yet, am I going to have to piece the parts out otherwise.
Kasey
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212594
04/09/12 11:20 AM
04/09/12 11:20 AM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
I don't know about a package. But I bought the comp cam hydraulic roller. 286hr I believe. Also went with Scorpion lifters. As I heard a few people having problems with the comp cam ones. I was going to give the Hughes lifters a try. But after buying the Scorpions I'm glad I went that way. Nice looking pieces.
Re: Hydraulic roller cam package for 400 BB [Re: 440forPOWER] #1212595
04/09/12 11:26 AM
04/09/12 11:26 AM
Scorpion huh? ill check into them. This is going to be a basic street car build, cast pistons, mild compression, yada yada yada. But where the guy lives he dosnt have access to any aditives so I figured this was the best way to go.
where did ya get the scorpion lifters?
Kasey
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212596
04/09/12 11:35 AM
04/09/12 11:35 AM
I found themin summit.
So are pushrods an issue on a big block?
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212597
04/09/12 12:39 PM
04/09/12 12:39 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Nope. You can either make and/or order whatever pushrods you need.
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212598
04/11/12 04:04 PM
04/11/12 04:04 PM
Up in the North and Far Away
AutoEngineer Offline
Here's a complete set from Lunati, cam, lifters, springs, retainers, locks, stem seals, cam drive
http://www.ebay.com/itm/LUNATI-383-440-M...b14&vxp=mtr
I bought a similar complete set, but with a hotter cam from Lunati for a 440 that I just rebuild and there is now a huge difference in behaviour of that engine compared to the last set up where i used a hydraulic flat tappet cam.
Similar roller idles smoother, has better vacuum and pulls much harder.
The next engine that I will rebuild, will get a roller cam too. The only disadvantage is a little bit higher price.
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212599
04/11/12 06:03 PM
04/11/12 06:03 PM
AndyF Offline
AndyF  Offline
Hughes Engines should be able to sell you a complete package. Don't forget, you'll also need a thrust button of some sort.
Re: Hydraulic roller cam package for 400 BB [Re: Moparnut426] #1212600
04/11/12 06:33 PM
04/11/12 06:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kasey
What heads are you going to use ? What is the definition of mild compression ?
Re: Hydraulic roller cam package for 400 BB [Re: AndyF] #1212601
04/11/12 06:34 PM
04/11/12 06:34 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also a bronze oil pump drive gear and shorter pushrods and probably an adjustable valvetrain.
