Re: What size front tires on your car?
[Re: SCATPK]
#1211671
04/08/12 03:27 AM
04/08/12 03:27 AM
Posts: 297 Oklahoma
TinCuda
Oklahoma
1971 'Cuda
215R65X15 w/ 7 inch rim up front.
275R60X15 w/ 8 inch rim on back.
I like the setup a lot.
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
[Re: SCATPK]
#1211675
04/08/12 12:19 PM
04/08/12 12:19 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
245/45-18 on the hot rod. I would prefer a bit more sidewall too but the tires already rub on the frame at full lock and I don't have any more room to the outside. The Imp wears 255/70-15 which is a 29" tire. It swallows those tires without any fear of rubbing anywhere. ![](/ubbthreads/images/graemlins/boogie.gif)
[Re: CUDA8U]
#1211679
04/08/12 06:03 PM
04/08/12 06:03 PM
Posts: 236 upstate, New York
jvcuda
upstate, New York
This is a good question , i was also wondering about the max tire size i can run on the rear of an e-body. I'm running 265 60 (26")on the rear and with the air shocks it looks like i could run a 28 or 29" . With 4:10 gears the taller the better until i change gears or buy a tremec OD
On my '73 cuda,I'm running ET street radials 295/55-15(28" tall) on a 8" rim. 295/65-15(30" tall) looks like it would work also.
[Re: GoodysGotaCuda]
#1211682
04/09/12 10:20 AM
04/09/12 10:20 AM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
On my steel wheels I am running 255/60/15 on all 4 corners...they are 15x7's
1MYTGTX
[Re: 1MYTGTX]
#1211683
04/09/12 10:22 AM
04/09/12 10:22 AM
1MYTGTX
S.I. N.Y.
With my Cragars I have 245/60/15 on front and 295/50/15 in the rear...all 15x8 wheels
1MYTGTX
[Re: MoparMarq]
#1211684
04/09/12 10:27 AM
04/09/12 10:27 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
245/45-17 on 17x8s front. 275/40-18 on 18x9.5s rear.
Would have preferred 50s on front and 45s on rear, but that didn't come in those sizes.
wow those look like space savers...especally on the back. Get some meat on those things bro. I have 205/75/15 front and 265/65/16's (I think) in the back.
