What size front tires on your car? #1211665
04/07/12 03:26 PM
04/07/12 03:26 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Just wondering what most of you guys are running in the front on your B&E Bodies? I am in need of some new front tires and really having a hard time choosing something that not only works well for street & highway driving but looks good. I currenty have 265-50-15 t/a`s up front and that size is no longer available and the pickens are slim for something that is similar in size.
Re: What size front tires on your car? [Re: SCATPK] #1211666
04/07/12 09:00 PM
04/07/12 09:00 PM
tucson az
frank Offline
frank  Offline
tucson az
On my 69GTX I have 245/60/15 on an 8 inch wheel. On my 68 Charger I have 235/60/15 on a 7 inch wheel. I like the look of the 245 better.
Re: What size front tires on your car? [Re: SCATPK] #1211667
04/07/12 11:02 PM
04/07/12 11:02 PM
New York
tt455 Offline
tt455  Offline
New York
Fronts are BFG 225/70/15 on 15x7's,and rears are BFG 275/60/15 on 15x8's.
I get many compliments on this set up.
Re: What size front tires on your car? [Re: frank] #1211668
04/07/12 11:30 PM
04/07/12 11:30 PM
STL
cdstl Offline
cdstl  Offline
STL
Could you post some pics of that? How about anyone else with an E body and 8" wide wheels up front or all of the way around?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: What size front tires on your car? [Re: cdstl] #1211669
04/08/12 01:06 AM
04/08/12 01:06 AM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Thanks guys keep them coming on what everyone is using. I have been running the 50series tire up front for so long it hard to think of a narrower tire filling the void. But some height would be nice.
Re: What size front tires on your car? [Re: SCATPK] #1211670
04/08/12 01:12 AM
04/08/12 01:12 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
235/60/15 up front, 275/60/15 out back.
Re: What size front tires on your car? [Re: SCATPK] #1211671
04/08/12 03:27 AM
04/08/12 03:27 AM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
1971 'Cuda
215R65X15 w/ 7 inch rim up front.
275R60X15 w/ 8 inch rim on back.
I like the setup a lot.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: What size front tires on your car? [Re: TinCuda] #1211672
04/08/12 09:08 AM
04/08/12 09:08 AM
Central NC
gch Offline
gch  Offline
Central NC
275/60r15 on rear and 235/70r15 on front.Have also run it with 255/60r15 on the front.8" on rear and 6.5" on front but have run 7" as well.
Re: What size front tires on your car? [Re: gch] #1211673
04/08/12 11:58 AM
04/08/12 11:58 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
265/50R15s on 15x8s on the Roadrunner; haven't driven it enough to put much wear on them, but if I were to change them I'd go with a 60 or maybe 70 series to get more sidewall height.
Re: What size front tires on your car? [Re: SCATPK] #1211674
04/08/12 12:07 PM
04/08/12 12:07 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Mickey Thompson S/R in 26x10x15. Roughly a 255/50 size.
Check into Maxxis Maurader. They do offer a 265/50x15 tire in a tread pattern like the old goodyear Gatorback. http://www.maxxis.com/AutomobileLight-Truck/Light-Truck-SUV/MA-S1-Marauder.aspx
Otherwise, 235/60 are pretty prolific and available from most manufacturers.
Re: What size front tires on your car? [Re: SCATPK] #1211675
04/08/12 12:19 PM
04/08/12 12:19 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
245/45-18 on the hot rod. I would prefer a bit more sidewall too but the tires already rub on the frame at full lock and I don't have any more room to the outside.
The Imp wears 255/70-15 which is a 29" tire. It swallows those tires without any fear of rubbing anywhere.
- Stu Harmon
Re: What size front tires on your car? [Re: feets] #1211676
04/08/12 12:49 PM
04/08/12 12:49 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
This is a good question , i was also wondering about the max tire size i can run on the rear of an e-body. I'm running 265 60 (26")on the rear and with the air shocks it looks like i could run a 28 or 29" . With 4:10 gears the taller the better until i change gears or buy a tremec OD
Re: What size front tires on your car? [Re: CUDA8U] #1211677
04/08/12 02:40 PM
04/08/12 02:40 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
anyone run or know if a 245/60 or 255/60 with a 15x8 wheel will clear the front fenders of a 68-70 b-body?
Re: What size front tires on your car? [Re: SCATPK] #1211678
04/08/12 04:23 PM
04/08/12 04:23 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
73 Roadrunner
295/50/15 on 8" wheel on back
235/60/15 on 7" wheel on front
Re: What size front tires on your car? [Re: CUDA8U] #1211679
04/08/12 06:03 PM
04/08/12 06:03 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
On my '73 cuda,I'm running ET street radials 295/55-15(28" tall) on a 8" rim. 295/65-15(30" tall) looks like it would work also.
Re: What size front tires on your car? [Re: SCATPK] #1211680
04/09/12 01:41 AM
04/09/12 01:41 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
245/45-17 on 17x8s front. 275/40-18 on 18x9.5s rear.
Would have preferred 50s on front and 45s on rear, but that didn't come in those sizes.
Re: What size front tires on your car? [Re: MoparMarq] #1211681
04/09/12 09:07 AM
04/09/12 09:07 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
255/45/17 and 295/45/18 stock spring location and wheel wells.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: What size front tires on your car? [Re: GoodysGotaCuda] #1211682
04/09/12 10:20 AM
04/09/12 10:20 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
On my steel wheels I am running 255/60/15 on all 4 corners...they are 15x7's
1MYTGTX
Re: What size front tires on your car? [Re: 1MYTGTX] #1211683
04/09/12 10:22 AM
04/09/12 10:22 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
With my Cragars I have 245/60/15 on front and 295/50/15 in the rear...all 15x8 wheels
1MYTGTX
Re: What size front tires on your car? [Re: MoparMarq] #1211684
04/09/12 10:27 AM
04/09/12 10:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
wow those look like space savers...especally on the back. Get some meat on those things bro.
I have 205/75/15 front and 265/65/16's (I think) in the back.
Coming soon!!!!
