B1 crankcase evacuation #1211534
04/07/12 10:44 AM
04/07/12 10:44 AM
B.C.
mk_ Offline OP
mk_  Offline OP
B.C.
Thinking of putting the crankcase evac vents and oil filler cap in the valley pan and leaving the B1 valve covers as cast with no holes.
I realize that a baffle may be required under the valley pan.
Has anyone done it like this and did it work okay?
Re: B1 crankcase evacuation [Re: mk_] #1211535
04/07/12 11:14 AM
04/07/12 11:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
B1 heads really dont have any bearing on this... but
I've put a vac pick up in the valley pan with a few
different style baffles and it didnt work well... it
still sucked up ALOT of oil
Re: B1 crankcase evacuation [Re: mk_] #1211536
04/07/12 11:33 AM
04/07/12 11:33 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
yes i tried it and no it didn't work, had plenty of baffling. ended up going to the VC, this was a b1 engine
Re: B1 crankcase evacuation [Re: jamesc] #1211537
04/07/12 12:39 PM
04/07/12 12:39 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Same here. Too much oil.
Re: B1 crankcase evacuation [Re: mac56] #1211538
04/07/12 12:53 PM
04/07/12 12:53 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I did it, worked fine with a baffle.
Re: B1 crankcase evacuation [Re: camastomcat] #1211539
04/07/12 03:03 PM
04/07/12 03:03 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
A few years ago I built a fairly intricate baffle on the on the underside of the valley cover, it still sucked WAY too much oil.
