Re: Bob's 69 340 4spd DaR/T
[Re: 70440+6bbl]
#1210246
01/26/13 03:05 PM
01/26/13 03:05 PM
Posts: 8,227 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Thanks guys. Here is a pic of an original air cleaner decal and wrinkle finish. The finish appears different than some I have seen.
Is the smooth border around the decal normal, as if the factory had taped off a spot to remain smooth for application of the decal? Or was the decal replaced?
[Re: ScottSmith_Harms]
#1210256
04/28/13 11:18 AM
04/28/13 11:18 AM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Ok lifes hopefully about to get back to normal. I used most of the car money I managed to save tward my middle daughters car (bought shortly before I left) I almost made it by to see Brent and his amazing Duster, but it was getting pretty late so I had to pass. Scott was a few hrs away so that had to wait as well. A long time friend does carbs as his side gig, I asked where to pick up my rebuild kit...... this was the end result of that conversation. Thanks Brian. It was even run on his test engine and it had crisp response. Today I want to check the fuel tank. Run some thinner thru the fuel lines to clean them. I'll need to find a coolant leak too. Cinco Demayo (the cars SPD) is coming and I want it driveable And for Tom, there should be video for you soon Things I will be after 1- Headliner in buckskin 2- AMD windshield 3- Windshield gasket if needed 4- Tie rod/balljoint boots to fit OEM 5- Mufflers 6- ABnE Dash pad 7- Legendary seat skins
