Back Half with 4 link photos #1207933
04/01/12 10:51 PM
04/01/12 10:51 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Doe anyone have any good photos or advice for completing a back half while keeping the existing floor pans. The new trend appears to be round tube. Any help would be appreciated.
Re: Back Half with 4 link photos [Re: Max Weg] #1207934
04/01/12 11:12 PM
04/01/12 11:12 PM
MI
68shifter Offline
68shifter  Offline
MI
Either way your going to have to modify the center alot to make stuff work. If you custom bend some round tube rails that's your best bet to keep alot of your factory floor. If you use a 2x3 setup they tend to arch way up in the center where you can keep the round tube down much better.
Body style of the car will matter as well as some have more dips/dives than others.
Good luck!
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Back Half with 4 link photos [Re: 68shifter] #1207935
04/01/12 11:13 PM
04/01/12 11:13 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
Here's some info for you on round tube frame under floor.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Kevin
Re: Back Half with 4 link photos [Re: 604 Hemi GTX] #1207936
04/01/12 11:31 PM
04/01/12 11:31 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
It is a 64 Savoy so yes it is somewhat limited to room. I appreciate the info!
