What can I expect in the 1/4? #1207387
04/01/12 12:39 PM
04/01/12 12:39 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
68 Dart
Gen 3 Hemi
Kenne Bell S/C 10lbs boost
Full weight
Tubular K fram , rack and pinion steering, coil overs
custom tri 4 link, 3.50 gears, ford 9", detroit locker, 325/50/25 MT drag radials
sub fram connectors, 8.50 molly cage..
Expected to make 625-650 RWHP
727
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207388
04/01/12 01:36 PM
04/01/12 01:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would say with 625 RWHP you should go low 10's with no trouble. Ron
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207389
04/01/12 01:36 PM
04/01/12 01:36 PM
southern California
1970sixpak Offline
1970sixpak  Offline
southern California
9.20
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207390
04/01/12 01:37 PM
04/01/12 01:37 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
http://www.race-cars.net/calculators/et_calculator.html
says 10.34 at 131mph. I'll guess if all goes well and that's enough gear 10.50 it also will have a lot to do with your converter...
Coming soon!!!!
Re: What can I expect in the 1/4? [Re: Mr.Yuck] #1207391
04/01/12 01:55 PM
04/01/12 01:55 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
so 10.50's to 9.20? bit variance there.. I was hoping for 9.80's out of the combo..
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207392
04/01/12 02:05 PM
04/01/12 02:05 PM
Az
Crizila Offline
Crizila  Offline
Az
Whats it weigh?
Fastest 300
Re: What can I expect in the 1/4? [Re: Crizila] #1207393
04/01/12 02:09 PM
04/01/12 02:09 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I'm not sure prolly 150 lbs lighter than a stock dart
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207394
04/01/12 11:35 PM
04/01/12 11:35 PM
Out West
408strokerdart Offline
Out West
I think you will hit your goal without issue. Probably has 9.60's in it though.
Re: What can I expect in the 1/4? [Re: 408strokerdart] #1207395
04/02/12 10:29 PM
04/02/12 10:29 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I hope so.. it would be cool to have a 9 sec car that I can drive on the street and be very reliable!
Re: What can I expect in the 1/4? [Re: W9 Dart] #1207396
04/02/12 10:44 PM
04/02/12 10:44 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You should hit that no problem mid to low nines if you are in the upper sixes hp.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
