Re: Mopar Marine conversion kits
[Re: FastOne]
#1207304
04/01/12 12:55 AM
04/01/12 12:55 AM
DaytonaTurbo
Manitoba, Canada
I don't think anyone sells complete kits. What parts are you looking for? Basically what you need are the water cooled manifolds unless it's something like a drag jet boat. Brass freeze plugs, water pump that's okay for water-only, marine type starter, alternator, carb, distributor. Flywheel, old bell housing or a plate to mount your starter to and the coupler that mounts on your flywheel to accept you drive's input shaft.
[Re: FastOne]
#1207309
04/01/12 11:03 AM
04/01/12 11:03 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
You do realize that engine power band and rpm need to be matched to boat load and propeller pitch/diameter?
[Re: dynamite]
#1207311
04/01/12 01:01 PM
04/01/12 01:01 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Glenwood Marine has a good selection a BB Chrysler parts for marine use. Aluminum front cover/mount and rear bell/mount will save weight over the OEM Chrysler Marine stuff. Their aluminum exhaust manifolds and risers will cut about 75 lbs of weight over the OEM iron parts. It's marine parts, expect to pay. OSCO replacement iron manifolds and risers are ~$750, the Glenwood pieces will be ~$1500.
