Page 2 of 3 1 2 3
Re: so tired of this!! nerves shot [Re: 70Cuda383] #1207071
04/01/12 11:10 AM
04/01/12 11:10 AM
middle Tennessee
mopower440 Offline OP
middle Tennessee
no, its not leaking down out of the wells, thats all good.
Re: so tired of this!! nerves shot [Re: mopower440] #1207072
04/01/12 12:04 PM
04/01/12 12:04 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
when i turn the key off, it will hit,
I remember threads where people had similar problems. Try doing a search. I plugged in "let off ignition" and came up with this one. Hope it helps...
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: so tired of this!! nerves shot [Re: mopower440] #1207073
04/01/12 01:34 PM
04/01/12 01:34 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
sometimes when im cranking and cranking and it wont fire, when i turn the key off, it will hit, if i do that a few times it will sometimes clear the plugs enough to start.
I think you found your problem ......It sounds like your ignition switch has a problem.
I have 2 cars that don't have chokes one is a 512 with a Holley 950 HP with no choke horn and electric fuel pump. The other is a 440 with a Holley 800 DP it has a choke and choke horn but it's not hooked up and a mechanical fuel pump. Both start about the same way after sitting for months. On the electric fuel pump car I turn the key on let the carb fill up then pump the thorttle 5 times crank with my foot off the throttle let it start and die pump the throttle 5 more times and start it nurse it along by tapping the throttle just enough to keep it running for about 30 seconds then rev it up to about 2,000 rpm in little burps a few times and it will idle. I do the same thing with the mechanical fuel pump car but before I do anything I crank the engine for a couple seconds to get fuel in the carb.
Re: so tired of this!! nerves shot [Re: GreenGlow] #1207074
04/01/12 02:14 PM
04/01/12 02:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
While I will agree it sounds like his ignition switch is faulty, I'm still inclined to point the majority of the poor start up blame at his lack of a choke and fuel evaporation. Keep in mind that choke realated issues are going to be more pronounced in cooler climates (you being in Arizona likely helps you a ton).
*The May 2012 Hemmings Muclecar Magazine has an excellent column write up by Ray Bohacz explaining how chokes work, one of the best write ups I've seen in laymans terms.
Re: so tired of this!! nerves shot [Re: mopower440] #1207075
04/01/12 10:17 PM
04/01/12 10:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There is your problem. The wiring to the ballast resistor has 2 circuits. The blue wire which has 12 volts with the key in the run position,but in the crank position it has 0 volts. The brown wire has 12 volts in the crank position only. If you lose the brown wire feed you will have no voltage to the coil during cranking.
Doug
Re: so tired of this!! nerves shot [Re: ScottSmith_Harms] #1207076
04/01/12 10:36 PM
04/01/12 10:36 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
oh i don't know. i know my car starts a lot like his car ( see my about post) i'm in jersey and it gets down in the 20's and 30's most winters and my chokeless dart doesn't go fouling plugs even on the coldest of days. the OP has an issue somewhere and i doubt its all the lack of a choke. yes it may be harder to start then a car with a choke or a car with a fat carb but it shouldn't be fouling plugs like he says its doing. probably has multiple issues thats causing it. and we probably aren't getting all the details either..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: so tired of this!! nerves shot [Re: abodyjoe] #1207077
04/02/12 12:17 AM
04/02/12 12:17 AM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Just a comment from one of the "old guard", I have noticed over the years that virtually EVERY mopar
I owned or knew of took a slightly different starting technique.The were (mostly)all very unique.
Some want the "pump like hell" deal, some you pump twice to the floor, then crack the throttle about 1/4 way and hit the key.
Some you do not pump at all, don't even LOOK at the gas pedal.If you pump, you flood, and you have to wait a half hour and try again.
I agree 100% that the Dart has some possible issues with ignition.Just sayin' it sometimes took me awhile to get exactly what that particular combo wante to start easy.
Re: so tired of this!! nerves shot [Re: 70Cuda383] #1207078
04/02/12 12:29 AM
04/02/12 12:29 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
Caught the part about the car firing while the key is released - verify power to the ignition while cranking and when key is released.
Had a B- Body that would only fire when key was released - found one of the wire terminals had backed out slightly in the connector body at the bulkhead connection
Dad was a journeyman electrician/ 30 yr CRC repairman. He found it in a few minutes. It's called "apparent power" - terminal is touching enough to show voltage on a meter but connection won't pass current.
Was pulling my hair out for days. I was 17 (24 years ago) but I won't forget the lesson - Thanks Dad.
Re: so tired of this!! nerves shot [Re: SSAAHemiFan] #1207079
04/02/12 03:07 AM
04/02/12 03:07 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Be sure to check the distributor connector. i had one slightly loose yesterday and it kept my 85 from starting even hot wired (I have a bad switch). Did the same, would kickback on turning the key off or disconnecting the coil power wire. also check the pickup coil.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: so tired of this!! nerves shot [Re: MoPar Jamie] #1207080
04/02/12 08:47 AM
04/02/12 08:47 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
BB Mopars are tough to start after a couple days especially with todays fuel. You should really have a choke, makes life a lot easier.It's really tough to hit the sweet spot before flooding. As was said, verify power to the coil in start mode. You may want to also verify spark voltage with an engine analyzer, you may have a weak coil, a bad connection or other bad ignition parts.
I have a 440 in a 69 GTX with stock AVS carb and stock choke. The guy that restored my AVS gave me this procdure, works every time. If it's set more than 2 or 3 days; Without pressing gas pedal run starter for 10-15 seconds. Pump gas pedal 2-3 times, (this sets choke and gives accelerator pump a couple shots), it starts right up. Of course if you run it daily, before the gas evaporates, just set the choke with one push to the floor and it starts instantly.
Re: so tired of this!! nerves shot [Re: MoPar Jamie] #1207081
04/02/12 09:18 PM
04/02/12 09:18 PM
middle Tennessee
middle Tennessee
Thats how this one does if its not 'too' flooded yet, just turn the key from run to off between cranking and it will kickback and apparently that burns enough off the plugs that it will start. Its too flooded this time and wont start, last time it did this i had to change the plugs.
Re: so tired of this!! nerves shot [Re: mopower440] #1207082
04/05/12 09:09 PM
04/05/12 09:09 PM
middle Tennessee
middle Tennessee
just tried to start it again after a few days and still wont start. in 'run' i have 4.5 volts at the coil, if i bypass the ballast and run a jumper i have 7 volts at the coil, at the ballast i have 10 volts, and the battery has 12.5 volts..i dont know if thats not enough juice at the coil but thats the way its always been and runs just fine, just a b..ch to start after it sets for a while..
Re: so tired of this!! nerves shot [Re: mopower440] #1207083
04/06/12 08:45 AM
04/06/12 08:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
losing 5 volts just in the wiring is a problem.
if you jumper over the ballast, you should have full battery voltage.
sounds like you've got bad wires with really high resistance, bad terminals on the wires, or both.
Check out all of your wires before something catches fire. pay close attention to any that pass through the bulkhead connector on the firewall.
**Photobucket sucks**
Re: so tired of this!! nerves shot [Re: 70Cuda383] #1207084
04/06/12 08:48 AM
04/06/12 08:48 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Try this as a short term troubleshoot, unhook the coil from the stock positive feed, and hook it to a fresh clean wire thats run straight to the battery.
you'll have to hook it up when you go to start, and unhook it when you're done driving, but it will allow you to see what happens when you get full voltage to the coil.
I bet it fires up like you put nitro in it!
Re: so tired of this!! nerves shot [Re: ScottSmith_Harms] #1207085
04/06/12 09:22 AM
04/06/12 09:22 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
My cars are in Boise Idaho. I live in Arizona but my toybox is in Boise.
Re: so tired of this!! nerves shot [Re: GreenGlow] #1207086
04/06/12 10:26 AM
04/06/12 10:26 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I had a Fuel pump issue with my Carter pump, if the car sat for longer than 2 weeks I would almost have to prime the system with fuel. Then I decited to try a Holley pump, That fixed it, Now the only time I have starting issues is if it sits for longer than 3 months, then it cranks for a few times, builds fuel PSI, and starts up.
You may have a few different issues, Hard to tell without standing there and seeing for my self, but ya may have a bad switch, and a fuel pump thats gone south.
Hope ya get it figured out. Oh and I run a holley 750 with out a choke and a proform main body, so its basically a race carb, and I dont have a lot of issues with it when cold.
Re: so tired of this!! nerves shot [Re: Moparnut426] #1207087
04/06/12 10:34 AM
04/06/12 10:34 AM
Moparnut426 Offline
Moparnut426  Offline
Also if your sick of replacing the wet plugs, I have had really good luck using a butaine, or propain "blazer" torch and heat them up to burn off the fuel. Saves ya some cash in parts.
Kasey
Re: so tired of this!! nerves shot [Re: Moparnut426] #1207088
04/06/12 04:00 PM
04/06/12 04:00 PM
mi
E
ERAT340 Offline
ERAT340  Offline
E
mi
Everyone, please. If you want to have fuel in your bowls the next cold start, block off your heat crossover. Its the only thing ever worked for me.
Re: so tired of this!! nerves shot [Re: ERAT340] #1207089
04/07/12 05:52 PM
04/07/12 05:52 PM
middle Tennessee
middle Tennessee
ok, tried jumping the coil straight to the battery and still no start..
Re: so tired of this!! nerves shot [Re: mopower440] #1207090
04/08/12 11:09 AM
04/08/12 11:09 AM
middle Tennessee
middle Tennessee
stuck another plug in one of the wires, getting a blue/purple spark. Dont know if its stout enough though, didnt make any snapping noise like you normally hear when sparking..
Page 2 of 3 1 2 3
