Cometic Head Gasket Installation ? #1206883
03/31/12 10:18 AM
03/31/12 10:18 AM
USA
K
krw71ragtop Offline OP
K
USA
Is there any prep work I need to do before I install these gaskets in a 416" small block with Edelbrock heads ? The motor had approx. 800 miles on it.
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206884
03/31/12 10:25 AM
03/31/12 10:25 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
I just installed a set on my rebuilt BB with Stealth heads. They said just clean them and install dry.
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206885
03/31/12 10:35 AM
03/31/12 10:35 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
block & heads need 50ra finish.
Re: Cometic Head Gasket Installation ? [Re: rickraw] #1206886
03/31/12 12:36 PM
03/31/12 12:36 PM
USA
K
K
USA
Whats 50ra finish ? Is this something I can do with a flat file or do they have to go to the machine shop ?
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206887
03/31/12 12:39 PM
03/31/12 12:39 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
you need a profilomter to check it!
Mopar Performance
Re: Cometic Head Gasket Installation ? [Re: rickraw] #1206888
03/31/12 12:50 PM
03/31/12 12:50 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
OR finer than 50 RA. Let's not scare the dude just yet.
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206889
03/31/12 04:26 PM
03/31/12 04:26 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That was rich !
I hope I am laughing with you here.
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206890
03/31/12 11:55 PM
03/31/12 11:55 PM
A 50 RA finisgh is real fine, so fine you shouldn't be able to see or feel lines between the cuts of the finish. It needs to be taken to a GOOD machine shop
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206891
04/01/12 03:48 AM
04/01/12 03:48 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
First time I installed them dry per the instructions. No problems.
I had to pull the heads to fix a rocker arm issue, and re-used the gaskets, but I coated them with the copper head gasket paint stuff, and have had no problems with that method either.
Re: Cometic Head Gasket Installation ? [Re: 451Mopar] #1206892
04/01/12 04:50 AM
04/01/12 04:50 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
They can be a pain to get sealed if the block/head surface aren't just right. Copper coat them before you put them on and it will help a ton.
Re: Cometic Head Gasket Installation ? [Re: viperblue72] #1206893
04/01/12 08:16 AM
04/01/12 08:16 AM
The Great White North
RAMM Offline
RAMM  Offline
As has been said --coat them with Permatex copper coat, let set up and install, on a properly prepared deck(head and block) surface. Your machine shop should use a PCD cutter for aluminum and a CBN for cast to get the proper RA/RV surface finish. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Cometic Head Gasket Installation ? [Re: RAMM] #1206894
04/01/12 08:31 AM
04/01/12 08:31 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I had to do a retorque on mine and was surprized it needed it
Re: Cometic Head Gasket Installation ? [Re: krw71ragtop] #1206895
04/01/12 09:39 AM
04/01/12 09:39 AM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
use and oil stone and some kroil....
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
Re: Cometic Head Gasket Installation ? [Re: Cab_Burge] #1206896
04/01/12 12:07 PM
04/01/12 12:07 PM
USA
K
K
USA
An answer with a good explanation ! Thank you Cab
I guess my mind reading isnt what it use to be on some of the above suggestions !
