Fuel sender leaking due to loose ring - reuse seal?
#1206752
03/30/12 11:23 PM
03/30/12 11:23 PM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I apparently didn't get the lock ring knocked all the way around when I reinstalled my fuel level sender, so now it's leaking pretty badly.
If I take the seal out and clean it and the mating surfaces off, should I be OK to reuse it? Nobody has these things around here, it took 5 days to get my last one. It's a brand new seal.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Fuel sender leaking due to loose ring - reuse seal?
[Re: Secret Chimp]
#1206753
03/30/12 11:26 PM
03/30/12 11:26 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Reuse the seal but if your lock ring is one of the new repos throw it away & dig out an original... They are 30%+ thicker & are much better at sealing the sender...
Post deleted by moparts
[Re: Secret Chimp]
#1206756
03/31/12 12:22 AM
03/31/12 12:22 AM
[Re: Andrewh]
#1206758
03/31/12 07:39 PM
03/31/12 07:39 PM
Secret Chimp
Eugene, Oregon
Man, you guys weren't kidding about these new lock rings. This is the original lock ring compared to the new one I got (Dorman 579006) - there's next to no height on the locking tangs compared to the new one! That or this is made of such cheap metal that they just get bent flat after the first install. Hopefully this is helpful for anyone searching in the future.
