What is your 451 or 470 Stroker Gas Mileage ~ No Joke
#1206607
03/30/12 05:51 PM
03/30/12 05:51 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
I am building either a 451 or 470 400 stroker and will run pump gas. Curious what your real world (not foot in it) gas mileage is. Most of the events I will be going to are about 100 mile round trips or more. Yes I will be driving it to the strip. I am really interested to hear mileage numbers. Please let me know recipe and also your gear ratio. I am building a street/strip motor but the reality is I need to drive to events and will. Any info appreciated
What was I thinking....
Re: What is your 451 or 470 Stroker Gas Mileage ~ No Joke
[Re: 72blubird]
#1206608
03/30/12 06:01 PM
03/30/12 06:01 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
[Re: 72blubird]
#1206610
03/30/12 06:21 PM
03/30/12 06:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Gear ratio and tire size plus weather its a auto or stick trans... and if they have a idea of the conv slippage rate
[Re: MR_P_BODY]
#1206611
03/30/12 06:28 PM
03/30/12 06:28 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
71 Swinger, 496 RB, 600 HP, 8 inch Continental convertor, 4.10 gear, 315 drag radial. about 6 or 7 miles per.
Yes I live in Michigan, so there is still 1 light on
[Re: 440dart]
#1206612
03/30/12 06:49 PM
03/30/12 06:49 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My 493 does about 6 to 7 miles per gallon I would say also. My old 440 got a good 12 miles to the gallon keeping my foot out of it. But I was surprised how much fuel the 493 uses. I did have to jet up alot and it seems to get about half the milage the 440 got. But I am not in this hobby to worry about gas milage because if I was I would be in a different hobby. Ron
[Re: 383man]
#1206614
03/30/12 06:58 PM
03/30/12 06:58 PM
72blubird
Minnesota
Thanks for the info guys keep em coming...it is great hearing about your combos
Yeah not in the hobby for gas mileage either, but the reality is costs are costs. Gas cost maybe a factor in how many events i do this year.
[Re: I_bleed_MOPAR]
#1206617
03/30/12 07:32 PM
03/30/12 07:32 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Mine is a mild 451 in a 72 Dart. Speedo never worked but am in the process of putting in a 6spd and EZ Efi. Should be ready in a couple months. Still won't have vacuum advance but I'm hoping for at least 15mpg.
Mopar to the bone!!!
[Re: danbob]
#1206619
03/30/12 07:55 PM
03/30/12 07:55 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Mild 493 ~530 hp, 3500 10", 3.55 29" tire, a solid 12-13 with normal driving, 750 vac sec holley, 11.50's in a 3400# B body
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1206620
03/30/12 08:06 PM
03/30/12 08:06 PM
Posts: 5,080 organ
maximum entropy
organ
mr. scamp runs 10.60, pump gas 496. 30" tall tire, 3.73 gear, 14 mpg @ 60 mph if i'm REALLY careful. if i touch the throttle? 0 mpg. hey, it takes fuel to make power. i think i could easily run it dry in 10-15 minutes of maniacal pedalfest.
[Re: OUTLAWD]
#1206621
03/30/12 08:11 PM
03/30/12 08:11 PM
Just wondering what you think the cost of towing the car home will be if you break down at the track? Would investing in a open trailer not be something to look at if you own a truck and if no truck then I hope you don't break down.
[Re: Triple Threat]
#1206623
03/30/12 08:42 PM
03/30/12 08:42 PM
Posts: 7,664 IN
ahy
IN
Mine's a 496. 10.2 CR, 243@.050 cam, EFI, 5 speed OD, 3.23 rear and 25" tires. It gets 14 highway at 75 or so. 11-12 around town. That's neither babying it nor riding it. If I ride it its in the single digits.
[Re: ahy]
#1206624
03/30/12 09:33 PM
03/30/12 09:33 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
First year we went on DragWeek, we took a 78 d-100 with a 496 and a Dominator. 6 to start out, then learned how to drive and jet it ended up at 9-10. Most guys were going down 10 jet sizes between driving, and racing with a Dominator. Got 12 last year with the stroker small block, 8" converter, and 3.89 gears...31 tall tire though.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: 72blubird]
#1206626
03/30/12 10:42 PM
03/30/12 10:42 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
I have a 440 motor with a 3.90 stroke crank and 4.350 bore, 464 C.I., Eddy RPM heads and stock type vacume six pak carbs jetted for best WOT performance, 10.5 to 1 compression ratio, Oregon non ethanol 91 octane pump swill. The car is a 3450 lb Duster with me in it and a full tank of pump gas, 4.10 gears and 315x60x15 M/T ET Street Radials tires, 727 with both a 10 inch and 8 inch converter. Best (SWAG)guessimate(speedo is off )is maybe 12 to 14 MPG driving it at road speeds doing the 55 MPH speed limit for any distances Local driving with a occasional blast to clean the plugs results in a lot less MPG The right foot controls the fuel milegages and the exposure to tickets Car runs in the high tens in the 1/4 mile with that motor I have a dual wide ban O2 system on the car and I ended up jetting the center carb. to have a AFR of 14.8 or higher, depending on throttle position, at 2100 RPM cruise
