Indy 440-1 heads that were built 8 years ago.... #1206571
03/30/12 04:56 PM
03/30/12 04:56 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
Does anybody know if Indy was having any problems with the heads they were producing 8 years ago...particularly the 440-1 Aluminum heads.
I am thinking about buying a used bare set and want to know what to look out for.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Blakcharger440] #1206572
03/30/12 05:07 PM
03/30/12 05:07 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
No problems that I know of with the 440-1. The only problem with buying bare heads is a lot of times by the time you get them ready to bolt on you end up with almost as much $$$ in them as a new set would cost.
If used I would buy them only after having a machine shop of my choice checked them out.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Indy 440-1 heads that were built 8 years ago.... [Re: MRMOPAR622] #1206573
03/30/12 06:35 PM
03/30/12 06:35 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my heads are about that old, they have a bit of porousity but not in any crucial places.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: rebel] #1206574
03/30/12 09:40 PM
03/30/12 09:40 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
No problems, Id say just as good as whats out there today.. I can dig up My receipt, but I purchased my set in the spring of "03" from Muscle motors... Hardly no port work, ran them like this for a few seasons, then sent them off to Modern Cylinder head for his Winter CNC port special.
Ran them this way for several years, until the fall of "09".
Only problem I had was a leak out of one of the header bolt holes, that were suppose to be blind.. Just thew on some sealant and a stud and that was fixed..
Went 146 MPH in the 8th mile in a heavy Dragster... Around 2300 lbs with driver. Mid 7's in the 1/4... People will say yea, its a pipe rack.. I dont care what its in one second flat 60ft and near a buck fifty in anything is damn fast regardless.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Bob_Coomer] #1206575
03/30/12 10:08 PM
03/30/12 10:08 PM
gregsdart Offline
gregsdart  Offline
bought mine in 1998 and haven't heard of any problems with them, mine were fine.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: MRMOPAR622] #1206576
03/30/12 10:45 PM
03/30/12 10:45 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
True, but the only way Id buy Indy's would be bare, all their hardware that they put in there is garbage.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Hot 340] #1206577
03/30/12 11:04 PM
03/30/12 11:04 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I bougth the 440-1s cnc 345s bare and did what I wanted
1.39 9.85 - 137 mph
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Ari440] #1206578
03/31/12 07:49 AM
03/31/12 07:49 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We been using 100s of sets of them since 1999 and have had no problems.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: B G Racing] #1206579
03/31/12 01:41 PM
03/31/12 01:41 PM
pa
572charger Offline
572charger  Offline
pa
aluminum -1s are good ! cast iron ones we had back in 1996 had problems with head bolt holes between the intake ports !!!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Indy 440-1 heads that were built 8 years ago.... [Re: 572charger] #1206580
03/31/12 09:37 PM
03/31/12 09:37 PM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I bought a set from Herb in 1993. They had a little bowl work done, but have 1500+ runs with still original guides and valves. I have been 7.70 with them. Best money I've ever spent. They are still going strong.
RIP
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Hot 340] #1206581
04/02/12 05:46 PM
04/02/12 05:46 PM
Mo.
racerx Offline
racerx  Offline
Mo.
x2 also if u r planing to run a bigger cam u will have to upgrade to better springs anyway.Ask me how i no.
Re: Indy 440-1 heads that were built 8 years ago.... [Re: sc4400] #1206582
04/02/12 05:48 PM
04/02/12 05:48 PM
Mo.
racerx Offline
racerx  Offline
Mo.
RIP
what kind of car is this pipe rack,1/8 mi or what?
Re: Indy 440-1 heads that were built 8 years ago.... [Re: Blakcharger440] #1206583
04/02/12 10:57 PM
04/02/12 10:57 PM
tn
robnbird Offline
robnbird  Offline
tn
WHAT IS THE PRICE ARE YOU GETTING? I DID NOT SEE THAT. VALVES, SPRINGS, S/PADS, RETAINERS, AND KEEPERS FOR SAY A .700 ROLLER CAM COULD BE AROUND $550 -$750 . sO IF THESE HEADS ARE 8 YRS OLD AND 8YEARS OF USE BE CAUTIOUS
Re: Indy 440-1 heads that were built 8 years ago.... [Re: racerx] #1206584
04/03/12 12:31 AM
04/03/12 12:31 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
1/4 mile dragster.
RIP
