Re: Indy 440-1 heads that were built 8 years ago....
[Re: Blakcharger440]
#1206572
03/30/12 05:07 PM
03/30/12 05:07 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
No problems that I know of with the 440-1. The only problem with buying bare heads is a lot of times by the time you get them ready to bolt on you end up with almost as much $$$ in them as a new set would cost. If used I would buy them only after having a machine shop of my choice checked them out.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: rebel]
#1206574
03/30/12 09:40 PM
03/30/12 09:40 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
No problems, Id say just as good as whats out there today.. I can dig up My receipt, but I purchased my set in the spring of "03" from Muscle motors... Hardly no port work, ran them like this for a few seasons, then sent them off to Modern Cylinder head for his Winter CNC port special. Ran them this way for several years, until the fall of "09". Only problem I had was a leak out of one of the header bolt holes, that were suppose to be blind.. Just thew on some sealant and a stud and that was fixed.. Went 146 MPH in the 8th mile in a heavy Dragster... Around 2300 lbs with driver. Mid 7's in the 1/4... People will say yea, its a pipe rack.. I dont care what its in one second flat 60ft and near a buck fifty in anything is damn fast regardless.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: MRMOPAR622]
#1206576
03/30/12 10:45 PM
03/30/12 10:45 PM
Posts: 3,395 Pa
Hot 340
Pa
The only problem with buying bare heads is a lot of times by the time you get them ready to bolt on you end up with almost as much $$$ in them as a new set would cost. .
True, but the only way Id buy Indy's would be bare, all their hardware that they put in there is garbage.
[Re: Hot 340]
#1206581
04/02/12 05:46 PM
04/02/12 05:46 PM
Posts: 4,070 Mo.
racerx
Mo.
x2 also if u r planing to run a bigger cam u will have to upgrade to better springs anyway.Ask me how i no.
[Re: sc4400]
#1206582
04/02/12 05:48 PM
04/02/12 05:48 PM
Posts: 4,070 Mo.
racerx
Mo.
I bought a set from Herb in 1993. They had a little bowl work done, but have 1500+ runs with still original guides and valves. I have been 7.70 with them. Best money I've ever spent. They are still going strong.
RIP
what kind of car is this pipe rack,1/8 mi or what?
#1206583
04/02/12 10:57 PM
04/02/12 10:57 PM
Posts: 914 tn
robnbird
tn
Does anybody know if Indy was having any problems with the heads they were producing 8 years ago...particularly the 440-1 Aluminum heads.
I am thinking about buying a used bare set and want to know what to look out for.
WHAT IS THE PRICE ARE YOU GETTING? I DID NOT SEE THAT. VALVES, SPRINGS, S/PADS, RETAINERS, AND KEEPERS FOR SAY A .700 ROLLER CAM COULD BE AROUND $550 -$750 . sO IF THESE HEADS ARE 8 YRS OLD AND 8YEARS OF USE BE CAUTIOUS
