Re: Ignition coil testing?
[Re: tboomer]
#1206339
03/30/12 09:37 AM
03/30/12 09:37 AM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
Anyone have an idea on testing a coil? I have an old Accel super coil on the car now. I swear that it came over on the Mayflower!! If I replace it,I am going with a new Firecore coil. I also would like to update the MP electronic dizzy to a Firecore but funds are pretty low...Has anyone one seen positive results from a hotter coil? Thanks!! Ted
I just had one of those fail...PITA to find it too. I was just bench testing them by the brightness of the arc, and their are much hotter ones than the Accel POS. A hotter coil is always better for racing, and Rick once said their Firecore coils are almost too hot, which is right about my speed, so I would get one of those. I did not have many different ones to bench test, I used what I had available, and I think it makes a big difference under load.
[Re: tboomer]
#1206347
03/30/12 10:46 AM
03/30/12 10:46 AM
BradH
...What if I could have found that magic .2 with...
STOP THINKING LIKE ME!!! It's a dangerous - and EXPENSIVE - pattern to get into.
Yeah, if all you wanted was .2, I suspect that going for different heads, etc., was freakin' overkill.
[Re: tboomer]
#1206349
03/30/12 11:01 AM
03/30/12 11:01 AM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
I did that once pre-msd. Ran every combination I could think of with orange box, chrome box, big ugly goofy looking yellow super coil, msd blaster 2 coil. Made a bizzillion passes that day and never found anything Would like to try the same type of test with an msd box and a few different/more up to date coils...but am thinking the same thing might happen. Maybe tuned on the hairy edge of lean, there might be more difference?
Rich H.
Esse Quam Videri
[Re: BradH]
#1206350
03/30/12 11:16 AM
03/30/12 11:16 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
What I can say is that certain coils are better suited to particular ignition boxes and applications
Exactly right. I have been testing different combinations on one of my big blocks on my dyno. What ignition system (box)are you running? The box/distributor/coil all have to work together. Mopar distributors use a pick up coil with very little resistance,and most similar magnetic pickups act the same. MSD's have a higher resistance but the box works differently. I answered another post a while back about this,and like I said there,I can't give away everything just yet due to a product I am testing for someone else. I have tested several coils,boxes,and a couple of distributors. The coil does not just make a hotter spark compared to another one,it turns low voltage into high voltage. The time it takes to "charge up" (rise time)and how long it takes to discharge the energy (spark duration) all make a difference. There are other factors too,but you get the idea.
Like I said though,I can't tell you everything yet but MP boxes work better with an Accel coil than an MSD on the dyno with their dist. And as I said in the other post,I need to get ahold of Rick @ Firecore and get some of his products to compare. I have reccommended his products to a few customers who were looking for new systems and/or wires before,so I guess I should test them to see how they work
Keith
[Re: tboomer]
#1206353
03/30/12 04:08 PM
03/30/12 04:08 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
Ted, there are different ratio windings on coils, 200 to 1 versus 400 to 1 and so on, these may not be the accurate ratio but you get the drift. I did some ignition box testing for Bill Hayes way back in yesteryear, one of his boxes used a standard point type coil, didn't matter what brand or for which car, another box, S4, had to use a specific brand and part number coil for the box to work correctly, it was faster on the car, NHRA stock 426 Street Hemi, than the stockdual points where. I later switch to the Mopar brand race ECU with the blue heat sink, it needed a specific Accel coil part number, that died at the track so I switch to a early MSD 404B, it required a Mallory 28880 coil to work properly, faster rise time to spark multiple times at idle and up in the RPM range That ignition made the car start and idle better when cold and it made the car pull in high gear in the smog of L.A. in the summer, 2 to 3 MPH faster than with the Mopar blue heat sing ignition I did some testing on a distributor machine one night at the local speed shop with that coil, we managed to burn up two MSD 5 boxes using that coil before we realized those MSD 5 boxes weren't compatable with that mallory coil My message is different coil ratio winding may be needed for different boxes
