Re: Subframe connectors any reasons not to have them?
[Re: MidPenMopar]
#1206171
03/29/12 09:12 PM
03/29/12 09:12 PM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
None that I know of. I had them on my 69 Bee and it was noticeably stiffer.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: dustergirl340]
#1206173
03/29/12 09:21 PM
03/29/12 09:21 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I've had them on my Duster for almost 10 years now. No cons here. Easier to jack the car up, drives better on the road, launches straighter at the track.
Ok that all sounds pretty positive!
[Re: MoparforLife]
#1206176
03/29/12 09:57 PM
03/29/12 09:57 PM
MidPenMopar
Just happen to have a set of competition engineering connectors for B body that I got for my runner and never got to use because I sold the car as a project. PM me if interested.
Ok I PMed you!
[Re: MidPenMopar]
#1206177
03/29/12 10:03 PM
03/29/12 10:03 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Only reason to me is if your building a totally stock original car... this wouldn't fit for your car
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 1_WILD_RT]
#1206180
03/30/12 01:06 AM
03/30/12 01:06 AM
MidPenMopar
I pretty much agree with this.. Stu you probably don't drive aggressively enough to justify subframe connectors but if you want to add them I don't see any reason not to... But if your gonna do it 1"x2" material isn't worth the trouble.... most guys use 2"x2" or 2"x3"...
Ok that's what i was looking to find out as to what is the way to go on them. Here's a set that Summit sells for $150.
http://www.summitracing.com/parts/CEE-3117/All/
[Re: DaytonaTurbo]
#1206186
03/30/12 12:47 PM
03/30/12 12:47 PM
Posts: 1,884 Tracy, CA, USA, Earth
rabid scott
"You're Where?"
"You're Where?"
I used the 2x3" square tube. Slot open the front part of the rear sub-frame and the square tube slides right in nicely so you can weld it all back together. Only downside to doing it this way is in the back seat feet area the tube comes thru the floor by about 1". It gives a real nice increase in torsional rigidity.
This is the exact way I do it!
[Re: MidPenMopar]
#1206187
03/30/12 03:26 PM
03/30/12 03:26 PM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
Be sure to add the 4 torque boxes when you add the sub-frame connectors. You may want to consider putting in a lower radiator support while your under there too.
I set mine back enough to clear the radiator tank on my '68. It's easier to put in that way, less intrusive and can be removed pretty easily in the future should the need arise.
You can see it tieing the bottom of the front frame rails together down in there just in front of the fan belt
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: MidPenMopar]
#1206190
03/30/12 04:10 PM
03/30/12 04:10 PM
Posts: 4,179 California
mickm
California
stu,
i'm installing the uscartool ones on mine, will be doing it at gordon's sometime in the future.
not sure i would have someone who isn't familiar with installing these on mopars do it though. gordon did the ones on herb's car, and the ones on john and brenda's car. i would talk with him about it.
[Re: MidPenMopar]
#1206191
03/30/12 04:22 PM
03/30/12 04:22 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Any reasons not to? sure; if your car is stock and you want to keep it unmodified. I didn't bother with them on my Purestock build as I figured it wouldn't need them with the polyglass tires. If I WAS going to do them, I would definitely use the US car tool contoured ones as I would not want to cut the floor. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: jbc426]
#1206192
03/30/12 05:16 PM
03/30/12 05:16 PM
Posts: 5,005 WI
Dcuda69
WI
Sorry to hi-jack, but do you have details on this engine compartment brace? Materials,etc.? Often thought of building one for my BB A-body
[Re: Dcuda69]
#1206193
03/30/12 05:34 PM
03/30/12 05:34 PM
jbc426
West Coast, USA
It's just some angle iron, DOM tubing and a small piece of steel plate at the cowl. Only had to drill a few holes on the cowl pinch weld. Other than those, it bolted on using exsisting bolts.
While not visible in that previous pic, there are also under fender braces and sub-frame connectors from US Cartool.
My factory front shock towers had started to break at the few spot welds that were there, so I welded all that back up as well.
While it's beyond what most people want to get into, it really has transformed the car's chassis.
[Re: 1_WILD_RT]
#1206194
03/30/12 07:14 PM
03/30/12 07:14 PM
Posts: 5,405 Pikes Peak Country
TC@HP2
Pikes Peak Country
Look at the subframe connector threads in the Cornering forum here. I doubt that 1x2 tubing would add that much torsional stiffness. The cowl crack is probably due to a hidden defect from the time the car was built or because of a collision long ago. I recall reading your posts, as I remember, you don't stress your car very much. The connectors may be a waste of effort and $$ if you drive conservatively.
Ehhh, I sorta agree but sorta disagree. Sub-frame connectors do not provide a huge amount of support for torsional stiffness, but they do help some. They do provide a large amount of help for increasing overall rigidity, particularly accelleration forces and they do a good job at reducing squeaks, rattles, and panel alignment changes that occur with a 40 year old car, regardless of how hard you drive it. This alone is worth their addition.
Similarly, while 2x3 or 3x3 bisecting the floor are better suited to the application, simple 1x3 tubing, even set in the flattest plane, will improve overall strength enouhg to be noticeable.
Think of it this way, your car is held together by spot welds, just like a shirt with buttons. Gaps between all those welds/buttons allow flex. Adding subframe connectors and/or torque boxes provides additional support for all those welds.
[Re: TC@HP2]
#1206195
03/30/12 07:37 PM
03/30/12 07:37 PM
Posts: 819 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I think subframe connectors would help for any car, regardless of how it's driven. My passenger side door seal squeaks whenever I get on or off the brakes with how the chassis flexes from the loading (I don't have connectors yet).
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: MidPenMopar]
#1206197
03/30/12 08:08 PM
03/30/12 08:08 PM
jbc426
West Coast, USA
I am looking into them primally to stop any more damage being done to the car having to go up and down the curbs to get in my parking spot. I put in some ramps but the poor car still has to twist a lot as my street is very narrow.
Adding torque boxes and the front lower radiator support when you do the subframe connector installation will help significantly for those types of torsional forces.
The under fender bracing and shock/cowl bracing are helpful too, but it's a lot more work.
[Re: MidPenMopar]
#1206198
03/30/12 08:21 PM
03/30/12 08:21 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
If your gonna do it consider these.. https://store.uscartool.com/66-70-B-Body-Frame-Connectors_p_13.html
A picture of them installed..
http://www.uscartool.com/img/70Superbird/index.html
Ok now i see how they did it. Looks like a very nice job on that Superbird.
If you want a "stock" look this is the way to go , I have CE's on the 68 Charger. Definitly helped IMO,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: bigD]
#1206199
03/31/12 08:14 PM
03/31/12 08:14 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Hey Stu Here is how mine look on my 70 GTX. I got these fron XV Motorsports. I am not necessarily promoting XV, just saying that is where I got mine. I witnessed a pair from US Car Tool being installed on a 69 Dart and not only was there much grinding and fitting required but there are places where they do NOT and will not ever meet the floor boards. Perhaps some of the gap s can be attributed to "chases" for routing brake lines and fuel lines but I didn't think it needed to be so much based on how the XV units fit....almost perfect out of the box and I had already replaced the floor pan with one from AMD. Never could understand why guys cut "slots" in the floor to do this other than it is easier to do.
Driving modern convenience in classic beauty
