Colorado Machine Shops? #1205483
03/29/12 12:41 AM
03/29/12 12:41 AM
Colorado Springs, Colorado
cool70cuda Offline OP
Is there anyone in Colorado (the Front Range..Ft. Collins to Pueblo) that knows of or has used a quality machine shop with modern equipment (computerised and use torque plates) and techs who know mopars?
Re: Colorado Machine Shops? [Re: cool70cuda] #1205484
03/29/12 10:00 AM
03/29/12 10:00 AM
Cascade, CO
reknapp52 Offline
reknapp52  Offline
Cascade, CO
Have you checked with Angelo at Geddes Auto Machine (Co. Spgs.)? Also maybe check with Madcap in Denver or Dave Slatten in Ft.Collins.
Re: Colorado Machine Shops? [Re: reknapp52] #1205485
03/29/12 10:31 AM
03/29/12 10:31 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
McCabe Motorsports in the springs has done several of my small block mopars over the years. He does excellent work, and I've never had a failure do to poor machine work. He's built several circle track mopars as well...he's also one of the few who has the bell housing and adapters to dyno mopar engines. (Geddes does too)
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Colorado Machine Shops? [Re: cool70cuda] #1205486
03/29/12 11:01 AM
03/29/12 11:01 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Madcap is likely to be the only shop that has a CNC block center and is somewhat Mopar knowledge. The other Mopar specific shops (Ridge Reamers, The Block Shop) are still using hammers and chisels but do have torque plates.
Keep your altitude in mind when you plan your build. You can/need to build more mechanical compression to compensate for density/altitude. Online calculators are a good tool for this.
Re: Colorado Machine Shops? [Re: 64Post] #1205487
03/30/12 11:51 AM
03/30/12 11:51 AM
SD
SG5438 Offline
SG5438  Offline
SD
Troy Kaiser at Hi Pro Engines does great work - 303-777-7678. Not all that modern but he gets it done. And he is a MOPAR man. His Dad used to run top fuel and he runs a Blown 392 in Fast 16.
Rick
2015 3500 Mega Cab Cummins
1970 Plymouth GTX - 7.99 @ 170 @ Bandimere
Re: Colorado Machine Shops? [Re: SG5438] #1205488
03/31/12 02:48 PM
03/31/12 02:48 PM
I wouldn't let Geddes turn a set of drums for me, seen way to many mistakes causing engine failures come out of his shop. McCabes seems to be out of bussiness?
I'll check out the others suggested! Thanks Guys
Re: Colorado Machine Shops? [Re: cool70cuda] #1205489
03/31/12 08:50 PM
03/31/12 08:50 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Ridge Reamer is probably your best bet. Just got my 500 back from them yesterday. Had them do tons of work over the years and never had a problem. Pete used to race a 383 Mirada, and they definitely know Mopar engines.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Colorado Machine Shops? [Re: cool70cuda] #1205490
04/01/12 03:39 AM
04/01/12 03:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
There are several shops that can do bore and Hone with torque plates. Not many with fixtures for correcting lifter bore alignment (MadCap) or installing aftermarket main caps.
The shop I used outsorced installing the main caps (got me a better price than when I called around), but I don't know who did the work?
The Block Shop is pretty good for the basic stuff, I have used then several times. I recently used them to machine my 505" stroker block. Align honed the mains, Bored and honed (with torque plates) the 440 block for 0.030" pistons. Measured the crank, rods and pistons to square deck the block for a zero deck height at TDC.
The other shops listed here in Denver, Ridge Reamer, Slatton have good reputations, but I have not personally used them.
Re: Colorado Machine Shops? [Re: 451Mopar] #1205491
04/01/12 03:06 PM
04/01/12 03:06 PM
Arizona
Chris'sBarracuda Offline
Arizona
Ridge Reamer is the Lupfers.. Pete and Joe.. Mopar guys..
Pete used to have a record holder Super Stock Dodge Magnum..
I used to have my stuff done there back when I lived there.
Chris..
Re: Colorado Machine Shops? [Re: Chris'sBarracuda] #1205492
04/01/12 06:11 PM
04/01/12 06:11 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Chris..
Only knock I've heard on Ridge Reamers is that they can be slow to turn work around. Otherwise, good guys.
Re: Colorado Machine Shops? [Re: 451Mopar] #1205493
04/01/12 11:12 PM
04/01/12 11:12 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I used to work for Dave Slattern super honest guy knows his stuff I would highly recommend him.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Colorado Machine Shops? [Re: 64Post] #1205494
04/02/12 12:09 PM
04/02/12 12:09 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
They turned my 500 around in about 2 months, including the waiting time for the stroker kit to come in. Once they had the parts, it was only about 2 weeks to finish. I consider that reasonable seeing as it's racing season and they are busy right now.
Matt
69 Dart Swinger 340
and even more
Re: Colorado Machine Shops? [Re: herkamer] #1205495
04/02/12 01:18 PM
04/02/12 01:18 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
You must be on the A-list. They wouldn't even return my calls.
Re: Colorado Machine Shops? [Re: 64Post] #1205496
04/02/12 02:24 PM
04/02/12 02:24 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I've only had them do a handful of work recently, mostly some small Onan 2 cylinders. After my 340 sat in their shop for almost 10 years, I'm surprised they didn't want full payment up front! I think the thing is they are not very office savvy. It's 3 guys trying to do everything. They still hand write the receipts! How much is a computer and Quickbooks?? Oh well, the work is quality.
Another good shop for general work I forgot about is Gunn Automotive. They are very reasonable but don't have torque plates for Mopar. For a cheapie build I would totally use them.
Matt
69 Dart Swinger 340
and even more
Re: Colorado Machine Shops? [Re: herkamer] #1205497
04/02/12 02:40 PM
04/02/12 02:40 PM
dogdays Offline
dogdays  Offline
I've had good luck with Ridge Reamer and friends have had good luck with The Block Shop.
BUT.......
If you want the latest high tech equipment and are willing to pay the price then Madcap is your place. If you have the $$$ go for it.
Plus they sell me Holley jets for $4 a pair.
R.
