heading to the left! #1205303
03/28/12 06:51 PM
03/28/12 06:51 PM
usa
lewtot184 Offline OP
usa
i've got a big issue with my 65 coronet. everytime i get on this thing in 1st gear it wants to pull to left, and i mean pull to the left! i steer into the pull and the car keeps drifting hard to the left. i literally tug on the wheel and the car won't even think about correcting. it's one voodoo child at WOT. i don't understand the problem at all. i've had this thing together for a few years and it's always been a leftie in 1st gear. now, this issue is with street tires but i've tried wide and skinny tires and the results are the same. i'm afraid to take this thing to test & tune because i don't won't an accident. i don't think the engine makes that much power, maybe 450-475hp. it has a stock street hemi suspension, car sits level, drives fine going down the road. anybody experience this?
Re: heading to the left! [Re: lewtot184] #1205304
03/28/12 07:01 PM
03/28/12 07:01 PM
Renton Washington
Triple Threat Offline
Renton Washington
What kind of rear end is in it?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: heading to the left! [Re: Triple Threat] #1205305
03/28/12 07:04 PM
03/28/12 07:04 PM
usa
usa
stock 8 3/4 with a 3.23 posi. tried a 3.55 and the results are the same. i think i have a chassis issue and ain't smart enough to resolve it.
Re: heading to the left! [Re: lewtot184] #1205306
03/28/12 09:00 PM
03/28/12 09:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How is it cruising along at 40 to 60 mph with your foot of the gas ? Ron
Re: heading to the left! [Re: lewtot184] #1205307
03/28/12 09:56 PM
03/28/12 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
From what your saying is this only happens when you
get on it... so I will assume it drives straight when
your just rolling down the road... I would look at
the rearend mounting... spring perches to see if the
rearend is moving
Re: heading to the left! [Re: 383man] #1205308
03/28/12 10:42 PM
03/28/12 10:42 PM
usa
usa
goes great! i think i have some kind of "torque steer" at WOT.
Re: heading to the left! [Re: MR_P_BODY] #1205309
03/28/12 10:44 PM
03/28/12 10:44 PM
usa
usa
rearend is moving
drives straight. what should i look at? the housing is the original, untouched perches.
Re: heading to the left! [Re: lewtot184] #1205310
03/28/12 11:17 PM
03/28/12 11:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep I agree with Mr P. Sounds like soething is moving in the drivetrain when you nail it. Such as spring bushing or mounting bolts loose or missing. If its an auto you may see if you can get it on a drive on lift and then power brake it a little being real careful. That way you can be under the car just like it is on the road and maybe see something moving a bit when you power brake it. But again I stress be very careful if you do that. Ron
Re: heading to the left! [Re: 383man] #1205311
03/28/12 11:31 PM
03/28/12 11:31 PM
gregsdart Offline
gregsdart  Offline
Better yet get a video phone/camera and have a buddy start it for you, pointed at the rear end and u bolts. Won't take long to figure out then. Check your spring perches to see if they have deformed or if the axle is moving on the spring.
Re: heading to the left! [Re: gregsdart] #1205312
03/29/12 12:12 AM
03/29/12 12:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If its steering that much I'm thinking the stud in
the spring is broke or gone that lines up in the spring
perch... and I would say its the left one thats broke
Re: heading to the left! [Re: MR_P_BODY] #1205313
03/29/12 12:30 AM
03/29/12 12:30 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Id check also for a diff problem or tire size ( roll out ) or axle spline stripped
Re: heading to the left! [Re: lewtot184] #1205314
03/29/12 01:01 AM
03/29/12 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not sure about this ... BUT maybe the posi is
taking a dump.. but I'm not sure if only one tire
would be slipping all the time..(I guessing that
when you changed gears you used the same posi)
Re: heading to the left! [Re: MR_P_BODY] #1205315
03/29/12 10:20 AM
03/29/12 10:20 AM
usa
usa
the studs are all there, u-bolts torqued to spec. i had this thing apart a couple of weeks ago and everything looks secure. i'll try a re-inspection and try some measuring. thanks.
Re: heading to the left! [Re: gregsdart] #1205316
03/29/12 10:22 AM
03/29/12 10:22 AM
usa
usa
a buddy suggested getting someone to watch the back and front while doing a wot in 1st. thanks for the reply.
Re: heading to the left! [Re: lewtot184] #1205317
03/29/12 10:52 AM
03/29/12 10:52 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I'd have to agree with the rear, but I would also check the motor mounts, as I had one go bad on a my Challenger and when I would jump on it, it would pull hard left ? under normall driving it was fine??? I look at anything, just go over the car with a wrench and check everything look for anything that maybe moving. If its that bad you will see signs of it somewhere.
Re: heading to the left! [Re: 70dusterjohn] #1205318
03/29/12 02:29 PM
03/29/12 02:29 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Also be sure to check the toe setting with the car jacked up a little in the front. If you had a tie rod starting to go it might start to steer the car when the front end comes up.
Re: heading to the left! [Re: Jeremiah] #1205319
03/29/12 04:37 PM
03/29/12 04:37 PM
organ
maximum entropy Offline
organ
i had a posi going bad that caused a really weird tail wag. with the spool, it doesn't do it no more.
