Re: heading to the left!
[Re: Triple Threat]
#1205305
03/28/12 07:04 PM
03/28/12 07:04 PM
Posts: 3,916 usa
lewtot184
usa
What kind of rear end is in it?
stock 8 3/4 with a 3.23 posi. tried a 3.55 and the results are the same. i think i have a chassis issue and ain't smart enough to resolve it.
[Re: lewtot184]
#1205307
03/28/12 09:56 PM
03/28/12 09:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
From what your saying is this only happens when you get on it... so I will assume it drives straight when your just rolling down the road... I would look at the rearend mounting... spring perches to see if the rearend is moving
[Re: 383man]
#1205308
03/28/12 10:42 PM
03/28/12 10:42 PM
Posts: 3,916 usa
lewtot184
usa
How is it cruising along at 40 to 60 mph with your foot of the gas ? Ron
goes great! i think i have some kind of "torque steer" at WOT.
[Re: MR_P_BODY]
#1205309
03/28/12 10:44 PM
03/28/12 10:44 PM
Posts: 3,916 usa
lewtot184
usa
drives straight. what should i look at? the housing is the original, untouched perches.
[Re: 383man]
#1205311
03/28/12 11:31 PM
03/28/12 11:31 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Better yet get a video phone/camera and have a buddy start it for you, pointed at the rear end and u bolts. Won't take long to figure out then. Check your spring perches to see if they have deformed or if the axle is moving on the spring.
[Re: gregsdart]
#1205312
03/29/12 12:12 AM
03/29/12 12:12 AM
MR_P_BODY
If its steering that much I'm thinking the stud in the spring is broke or gone that lines up in the spring perch... and I would say its the left one thats broke
[Re: lewtot184]
#1205314
03/29/12 01:01 AM
03/29/12 01:01 AM
MR_P_BODY
I'm not sure about this ... BUT maybe the posi is taking a dump.. but I'm not sure if only one tire would be slipping all the time..(I guessing that when you changed gears you used the same posi)
[Re: MR_P_BODY]
#1205315
03/29/12 10:20 AM
03/29/12 10:20 AM
Posts: 3,916 usa
lewtot184
usa
the studs are all there, u-bolts torqued to spec. i had this thing apart a couple of weeks ago and everything looks secure. i'll try a re-inspection and try some measuring. thanks.
[Re: gregsdart]
#1205316
03/29/12 10:22 AM
03/29/12 10:22 AM
Posts: 3,916 usa
lewtot184
usa
a buddy suggested getting someone to watch the back and front while doing a wot in 1st. thanks for the reply.
