the hemi started smoking out the exh ?**update**
#1205233
03/28/12 05:34 PM
03/28/12 05:34 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
At first i thought it was the intake not sealing as i had ran into the problem of having to to use 2 gaskets on the sided to fill the gap when i pulled the intake off i looked for signs of sucking oil in the runners but all were clean n dry i havent changed the break in oil yet its supper thin any chance its getting by??? its not really a blue smoke like a normal oil burner not black from rich and not really like a vapor from water it stareted doing it after putting the new exhaust(with x pipe) on the car so hard to tell what bank it coming from ![](/ubbthreads/images/graemlins/shruggy.gif)
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: the hemi started smoking out the exh ?????
[Re: toplescuda]
#1205234
03/28/12 05:49 PM
03/28/12 05:49 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Could it just be burning the paint off the new exhaust?
[Re: Dodgeguy101]
#1205235
03/28/12 06:01 PM
03/28/12 06:01 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
No im pretty sure thats not it possible that oil from valve cover gaskets (cork) getting down between header and blow out the exh.????just a thought cause the valve cover gaskets are mega thick and im having to keep snuging thek down ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cudajon]
#1205237
03/28/12 08:24 PM
03/28/12 08:24 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
has the motor gotten badly flooded when first started or recently
home of the Sox and Martin Hemi Duster
[Re: toplescuda]
#1205238
03/28/12 08:45 PM
03/28/12 08:45 PM
Posts: 833 MN
hemidup
MN
One of the last Hemi's I built smoked like a mother at the dyno at start up. The dyno operator even questioned me if I installed the second ring upside down. That's how bad it was. The smoking problem came from priming the engine prior to start up without without sparkplugs. After the dyno session the car ran its best times ever.
Jerry Williams.
[Re: hemidup]
#1205239
03/28/12 09:43 PM
03/28/12 09:43 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Iv had it running couple times drove it off the trailer into muffler shop all is good got home frpm exhaust fired it up to back off trailer and it was puffing pretty good as mentioned before i just fig the intake finally sucked oil up into the port is it even possible header gasket oil soked form trying to get valve cover to seal if pulled plug would it show on plug this soon?
[Re: toplescuda]
#1205240
03/28/12 11:15 PM
03/28/12 11:15 PM
HEMIFRED
SOUTH JERSEY
if leaking into intake port beware if detonation
[Re: HEMIFRED]
#1205242
03/28/12 11:44 PM
03/28/12 11:44 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
So your saying the plug may not he sealing well? tubes are brand new no washers on the spark plugs
[Re: toplescuda]
#1205243
03/29/12 12:13 AM
03/29/12 12:13 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Ok went down and pulled a plug off each cyl on one bank they got burnt oil under the eletrode hhhh so sence the intake if off i looked into the ports at back side of the valve there is all kinds of oil puddeled up on top of each valve that is closed/sealed what the heck?
[Re: MR_P_BODY]
#1205245
03/29/12 12:35 AM
03/29/12 12:35 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Man dude dont tell me that lol i had the valve springs replaced and gang raped me for over 700 bucks to just put new springs on and i know it had seals on it when i took it to them i do not want to pull this motor again or yank the heads to put seals on
[Re: toplescuda]
#1205247
03/29/12 12:43 AM
03/29/12 12:43 AM
Posts: 382 Roseville MN
72swgnr
Roseville MN
Use compressed air to hold the valves up and replace them while the motor is in the car and the heads are still on ![](/ubbthreads/images/graemlins/wave.gif)
[Re: toplescuda]
#1205248
03/29/12 12:44 AM
03/29/12 12:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You dont have to pull the heads or engine... but you would need the on head valve spring compressor and a air compressor to blow the cyl up ![](/ubbthreads/images/graemlins/wave.gif)
[Re: HEMIFRED]
#1205249
03/29/12 12:47 AM
03/29/12 12:47 AM
MR_P_BODY
both valves? intake and exhaust ?
LOL Fred... pretty hard to see the exhaust valve looking in the intake port... just messin with ya ![](/ubbthreads/images/graemlins/wave.gif)
Re: the hemi started smoking out the exh ?**update**
[Re: toplescuda]
#1205251
03/29/12 02:15 AM
03/29/12 02:15 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
One side man thats a lot of oil i did notice that when took plugs out only one was tighter then snug few of them i could of took out by hand all tubes had a lot of oil in them even before i undid the plugs that cant be normal
