Lunati Springs
#1204556
03/27/12 04:15 PM
03/27/12 04:15 PM
Posts: 93 CA
mojavered
CA
How do the Lunati springs hold up compared to other brands? I am recommended to use Lun 73124 springs. Please let me know what your thoughts are. Thanks!
71 Challenger RT 440 / 727 / 8.75
Re: Lunati Springs
[Re: mojavered]
#1204559
03/28/12 01:06 PM
03/28/12 01:06 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I used Lunati springs on a couple roundy round small block chevies I built. Held up well. I admit they were not very aggressive cams or springs though, but they did have the pee run out of em.
Re: Lunati Springs
[Re: BradH]
#1204561
03/28/12 03:36 PM
03/28/12 03:36 PM
Posts: 5,875 communist bloc of new jersey
jamesc
I think most of the springs available today from a wide variety of companies are really made by only a few actual spring companies.
you can bet on that, as are retainers and many other items. in some cases the manufacture may not even normally be associated with or have a commonly know name in the aftermarket. you can bet that all the companies selling springs don't have the equipment to wind and heat treat springs. years ago i was researching retainers and noticed at that time k-motion retainers were the dimensionally exactly the same as manley only the specs as listed were reversed.
Re: Lunati Springs
[Re: jamesc]
#1204562
03/28/12 07:55 PM
03/28/12 07:55 PM
Posts: 93 CA
mojavered
CA
Thanks for the help and info. I will check around at the others that are the same spec and look at price then. Jason
Re: Lunati Springs
[Re: mojavered]
#1204563
03/29/12 06:57 AM
03/29/12 06:57 AM
Posts: 90 NL
Frederick
NL
PAC and PSI are regarded as the top of the line, if you're looking for that.
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
