Re: Overheating Circle Track Engine
[Re: BillNC]
#1203882
03/26/12 03:17 PM
03/26/12 03:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you check the timing again... if the 2 wires at the dist are backwards they will change the timing... alot of those wires were backwards in the plug
[Re: MR_P_BODY]
#1203883
03/26/12 03:39 PM
03/26/12 03:39 PM
Posts: 135 NC
BillNC
NC
To answer your question, we have not yet re-checked the timing but is in on the schedule asap. Will follow up with a post.
Also, we are using the springs (heavy silver) that came installed in the MSD distributor. I think we need to change them. Any suggestions?
[Re: BillNC]
#1203884
03/26/12 03:58 PM
03/26/12 03:58 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
The MSD box WILL retard timing over stock control module. A MSD 7AL3 is about 4 degrees retarded from a MSD 7AL2. I've seen that first hand plenty of times from dyno tuning (Dyno box) compared to the car's ignition box. I would bet it's even more compared to a stock module. The reason is the MSD unit will take more time to do it's processing over a regular ignition module. Check timing and report back what you find.
[Re: BillNC]
#1203885
03/26/12 03:59 PM
03/26/12 03:59 PM
MR_P_BODY
I use the lightest springs... I just use the retarted point just for starting... for me anything beyond starting I'm at full advance... also check to see what you advance to(they have different bushings for different amounts of advance) I would think you want about 18* initial and maybe 34* total(guessing)
[Re: BillNC]
#1203886
03/26/12 10:11 PM
03/26/12 10:11 PM
Posts: 43,323 Bend,OR USA
Cab_Burge
If you weren't burning all the fuel before the switch and IF IF the new ignition is burning the fuel better then your probally making more power now than before, that said, more power always makes more heat Check the total igniton timing first All the NHRA stocker 340 drag motors I have worked on like 30 to 32 degrees total timimning, that was a long time ago using VP C12 race gas
[Re: BillNC]
#1203889
03/28/12 01:41 PM
03/28/12 01:41 PM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
Our plugs were gapped at 30. Should we adjust this also? The engine would pop a little when I let off in the turns.
.030"-.035" is fine for plug gap. Like everyone said, check the timing! I bet it is retarded.
[Re: BillNC]
#1203891
03/28/12 02:16 PM
03/28/12 02:16 PM
MR_P_BODY
A leaky header or fuel in the pipes will cause that... and if the timing is retarted
[Re: MR_P_BODY]
#1203892
03/28/12 04:04 PM
03/28/12 04:04 PM
Posts: 1,051 The Great White North
RAMM
Ran into this last year on a friends circle track (Mopar) effort. Mid season an MSD box was installed due to ingition issues---Ran the whole season with sluggish performance that did not match the expectations---Checked the timing with 3 races to go and found out it was 8 yes EIGHT degrees retarded! Of course the last 3 races were rained out so we can only speculate --coulda/woulda/shoulda. You should observe a retarded timing condition. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#1203893
03/28/12 04:31 PM
03/28/12 04:31 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Help a guy out here. Are you saying with just a box change the timing will change? Educate me, how could the timing change if the distributor wasn't moved? The box does something to the timing even though the distributor isn't moved? How would you set the timing then?
[Re: Dodgeguy101]
#1203894
03/28/12 04:40 PM
03/28/12 04:40 PM
Bigcube
Upstate NY
Because the MSD/ignition module interprets the signal from the magnetic pickup and then sends the signal to the coil to fire the cylinder. MSD will do extra processing from magnetic pickup signal and thus cause a delay between when the signal for the pickup is received to when the signal to fire the plug is sent. More processing means a delayed signal to coil to fire the plug, thus the timing is retarded.
[Re: Dodgeguy101]
#1203895
03/28/12 04:56 PM
03/28/12 04:56 PM
Bigcube
Upstate NY
And to answer your second question you advance the timing by advancing the distributor, you just need to send the signal sooner to the MSD so the plug fires when you want it to. IE, you need to account for the delay due to additional MSD processing.
[Re: Bigcube]
#1203897
03/28/12 05:45 PM
03/28/12 05:45 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Ok, so for the sake of discussion, I set the total timing to 36, you are saying I need to set for say 37 or 38 to allow for the delay? Or if I wanted 18 initial, set it for 20 or 21? How do you figure what the delay is? I may be making this harder than it is.
