MP Shift Improver Kit P4349469 w/Shift Kit?
#1203542
03/25/12 11:13 PM
03/25/12 11:13 PM
Posts: 164 Alberta.......
silvercloud
Alberta.......
Hi-many many moons ago I added the MP P4349469 shift improver kit to a 727 I installed in my '76 D100 behind a 360. IIRC it contains a modified front servo, a blocker rod for the accumulator, and a spring for the rear servo? It was installed in conjunction with a 5.0 front band lever into a basically stock transmission I salvaged out of a Cordoba. Been so long ago that I can't even remember what it shifted like. Still have the transmission sitting around-I'm thinking about salvaging the stuff and installing it into a BB case 727 I'm going to rebuild to go behind a mild 400 in my '74 Charger, and installing the Transgo TF2 kit at the same time? So the question for the tranny gurus is-good or bad idea to combine these parts?
Thanks in advance Jason
An '06 3500 QC 4x4 Laramie CTD with a 6.7 named "Frankentruck", an '80 W200 CC 440/435 yard truck, a Dakota, a Hemi Ram, and a bunch of projects....still working on resurrecting my '74 Charger after a 25 year hiatus for a "quick paint job"! Now a '78 D150 shortbox factory 440 to keep me occupied.
Re: MP Shift Improver Kit P4349469 w/Shift Kit?
[Re: JohnRR]
#1203544
03/26/12 12:21 PM
03/26/12 12:21 PM
silvercloud
Alberta.......
What effect will the accumulator blocker rod have in conjunction with the increased line pressure the shift kit provides?
Thanks Jason
[Re: silvercloud]
#1203545
03/26/12 05:34 PM
03/26/12 05:34 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Transgo used to supply a blocker rod with the TF-2 kit but they don't anymore, it makes the 1-2 upshift pretty harsh. Some like it that way, others............
[Re: John_Kunkel]
#1203546
03/26/12 05:55 PM
03/26/12 05:55 PM
silvercloud
Alberta.......
Guess there's only 1 way to find out right? Good thing the purchase price of the kit has been amortized over 25 years as it appears at the end of the day I may use none of it!
Thanks Jason
