Re: Take a look at my forged 6.1 hemi build.
[Re: Bigcube]
#1203492
03/26/12 05:23 PM
03/26/12 05:23 PM
Posts: 243 United States
W9 Dart
United States
Not sure how you can change a piston and not need to balance the rotating assembly unless the replacement piston is the exact same weight of the pistons that were balanced into the crank originally. Please enlighten me, I would like to learn?
That is exactly what the deal is.. these pistons were designed by DAve Webber who made them the exact weight of the stock pistons.
[Re: W9 Dart]
#1203493
03/26/12 06:28 PM
03/26/12 06:28 PM
Posts: 3,875 Smyrna, South Carolina
STEFF
Balmar what do you think the cause of the broken rod was?
Stock parts in an abusive environment. It wasnt the bolts that let Loose as the big end was still attached to the crank. The motor let go at 6000 rpm. No sign of valve float.
[Re: STEFF]
#1203494
03/26/12 07:15 PM
03/26/12 07:15 PM
W9 Dart
United States
Still strange... stock parts letting go at 6000 rpms.. not a common occurrence.
[Re: fishy340]
#1203496
03/26/12 08:55 PM
03/26/12 08:55 PM
W9 Dart
United States
i believe the 6.1 comes w forged pistons and rods.
no the 6.1 is only a forged crank, the pistons are not great for anything other than N/A and the rods are powdered.
[Re: W9 Dart]
#1203497
03/27/12 01:43 PM
03/27/12 01:43 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Nice build! I run 6psi with a procharger. These new hemis are pretty fun. Good luck with the build, 10psi with that cam is alot more air then 10psi stock. You need to post some vids of that beast in your hot rod running. It's going to be wild ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: W9 Dart]
#1203500
03/31/12 02:15 AM
03/31/12 02:15 AM
Posts: 1,828 houston texas
gremlinsteve
houston texas
is that the same car that was at lee's place for a while
if so it has changed alot. nice looking car now
if You Like Gremlinsteve. Gremlinsteve Likes You.
