thinnest headgasket for magnum engine? #1202927
03/25/12 12:55 AM
03/25/12 12:55 AM
Milwaukee, WI
Prince_Valiant Offline OP
Milwaukee, WI
Are there enough choices out there that I can find one with compressed thickness of .020, or at least less than .040? tia,
chris
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: thinnest headgasket for magnum engine? [Re: Prince_Valiant] #1202928
03/25/12 12:57 AM
03/25/12 12:57 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Mr. Gasket 1121G .028 compressed...
$20.00 each
http://www.summitracing.com/parts/MRG-1121G/
Tony
70 AARCuda Vitamin C
Re: thinnest headgasket for magnum engine? [Re: 70AARcuda] #1202929
03/25/12 12:59 AM
03/25/12 12:59 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
Re: thinnest headgasket for magnum engine? [Re: 70AARcuda] #1202930
03/25/12 01:04 AM
03/25/12 01:04 AM
Milwaukee, WI
Milwaukee, WI
thank you...though I wasn't sure if these worked for post 92 magnum based small blocks?
Re: thinnest headgasket for magnum engine? [Re: Prince_Valiant] #1202931
03/25/12 01:14 AM
03/25/12 01:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
magnum can use the LA head gasket..
Tony
Re: thinnest headgasket for magnum engine? [Re: 70AARcuda] #1202932
03/25/12 12:38 PM
03/25/12 12:38 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Anyone have an opinion
On how close
The top ring upper surface
Can come to the bottom of the head gasket?
Some of the engines
That have done well in
Enginemasters competition
Seem to gain a bit
By combining the
Crevice volume of the head gasket
With the crevice volume above the top ring
Reducing total crevice volume
Usually results in
Less unburned fuel
More power, better fuel economy
Re: thinnest headgasket for magnum engine? [Re: 360view] #1202933
03/25/12 12:56 PM
03/25/12 12:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Do you mean how thick is the top ring land? All the newer motors from OEs are getting pretty thin up there they are doing it for the reasons you mentioned. They are also mostly useing hypereutechtic pistons to reduce piston expansion so they can run tighter clearance above the top ring and therby reduce cold start emmisions. Some makers are putting piston number stamps on the bottom of the piston instead of the top to further reduce crevace volume so I would say it is pretty important.
