Re: NEVER believe a SRT Engineer [Re: ZIPPY] #1201099
03/28/12 04:40 PM
03/28/12 04:40 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Do you know if the 09 5.7 factory replacement piston and rod assembly come in oversize bores?
Re: NEVER believe a SRT Engineer [Re: MattW] #1201100
03/28/12 05:47 PM
03/28/12 05:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Never seen that on the pistons but in the interest of full disclosure will mention I have only built the
2008-down 5.7s. There was only two PNs for piston and rod assy's, left and right bank.
Bearings are another story though, different letter codes are used for the bearings so the clearance can be fine tuned slightly.
Rich H.
Esse Quam Videri
Re: NEVER believe a SRT Engineer [Re: ZIPPY] #1201101
03/28/12 08:14 PM
03/28/12 08:14 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Same as the 09 and up. So its probably stock size. Thanks
Time for aftermarket.
Re: NEVER believe a SRT Engineer [Re: MattW] #2369265
09/12/17 08:58 AM
09/12/17 08:58 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
the area behind the timing gear/oil pump drive is what needs to be machined.
Blue back ground photo is 03-08 crank
The other is a VVT crank.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: NEVER believe a SRT Engineer [Re: MattW] #2369369
09/12/17 01:11 PM
09/12/17 01:11 PM
P
Paul_Fancsali Offline
P
They sound like Fords every engine is different you will soon find it impossible not to use anything but stock parts
Re: NEVER believe a SRT Engineer [Re: Paul_Fancsali] #2369534
09/12/17 05:52 PM
09/12/17 05:52 PM
dogdays Offline
dogdays  Offline
It shouldn't be different in Canada, maybe it is: But in the USA, TONER is what you put in a Xerox machine.
A TONE RING is what through some pickup device, tells the computer how fast the shaft is turning and in some cases, where it is on the rotation.
And I thought it was just a couple of days ago where the conversion tone rings were mentioned and their suppliers specified.
All these different tooth counts make no real sense, when Electromotive standardized the 60 - 2 tooth wheel around 15 years ago.
R.
Re: NEVER believe a SRT Engineer [Re: MattW] #2370096
09/13/17 03:00 PM
09/13/17 03:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
No where near as bad as ford yet but they are trying.
This should be in the Gen III area, good info here.
