line lock ? #120029
09/13/08 01:12 PM
09/13/08 01:12 PM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
can a line lock also be used as a parking brake or does the car have to be running for it to werk
Re: line lock ? [Re: mikepar] #120030
09/13/08 01:31 PM
09/13/08 01:31 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Not recommended because you need power on the line lock and this will drain the battery.
I think JCwhitney has a mechanical hydraulic brake lock
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: line lock ? [Re: HealthServices] #120031
09/13/08 01:31 PM
09/13/08 01:31 PM
Richmond, VA
VT_Dart Offline
VT_Dart  Offline
Richmond, VA
Yup. They're also not designed to be used for prolonged periods of time or they're susceptible to burning up.
Darrah Heath
Re: line lock ? [Re: mikepar] #120032
09/15/08 05:14 PM
09/15/08 05:14 PM
pittsburgh,Pa.
mikepar Offline OP
mikepar  Offline OP
pittsburgh,Pa.
thank you
mike
