1971 340 Water Pump Bolt Detail #1199173
03/18/12 07:47 PM
03/18/12 07:47 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
Bought a reproduction small block water pump bolt kit and need to know which bolt goes where.
There are 7 bolts;
4 long (2 with "LE" and 2 with triangle on head) - what position do these go top or bottom/left or right?
The other 3 bolts I know where they go.
There are 2 loose washers, which bolts get these washers?
Re: 1971 340 Water Pump Bolt Detail [Re: JAK] #1199174
03/18/12 08:00 PM
03/18/12 08:00 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
long bolts go above and below the water passages (holes) on each side of block..... use a sealant on those 4 bolts two as coolant can leak (same with 4 exhaust studs)
Re: 1971 340 Water Pump Bolt Detail [Re: UCUDANT] #1199175
03/18/12 09:41 PM
03/18/12 09:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The fastener guide doesn't list any WP bolts having an LE marking. They list the 4 long bolts as having an F with a circle around it. The bottom two bolts are listed as having an A in the center.
My 73 had two of the F bolts and two with a D. The other two lower bolts have a TR on the head.
The fastener guide says that 1 loose washer goes on the lower left bolt.
