Headlights cut out 1996 Dakota. #1198791
03/18/12 03:06 AM
03/18/12 03:06 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
I had a problem that started a few weeks back on my '96 Dakota Sport. driving down the road at night the headlights went dark..i fiddled with the knob for the switch and they came on. days later did it again...a little more effort and they flickered on, off..on, then again..finally made them stay.
I figured switch needed replaced..I kept that in mind. The other night they worked fine, and 20 minutes later i had to go back out. Dead..wouldn't come on at all..I've always had running/parking lights but dimmer and brights were just out.
So next day I go to O'Reilly and get a new switch. I replace it no problem. Hey I have lights. I did noticed on of the connectors on the plastic pigtail had a little melted spot. didn't seem to be any problem phyisically beyond that so I put it in.
Worked great last few nights, very crisp signal on or off.
Then tonight I was driving a backroad with brights on, then boom, out lights go..I slow down and fiddle with switch..nothing..then boom, there are lights..it popped out on me again..made me nervous as I was on the highway for a moment and there was not much light via light poles or moon, etc. I just wanted to get home.
What else could this be? I always thought headlights were hardwired in to avoid that stuff. Never had an issue like this on my old cars.
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Headlights cut out 1996 Dakota. [Re: MonGoo$e] #1198792
03/18/12 04:36 AM
03/18/12 04:36 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
bad hi/low dimmer switch
I am truckless..
Re: Headlights cut out 1996 Dakota. [Re: 340SHORTY] #1198793
03/18/12 10:42 AM
03/18/12 10:42 AM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
is that one in the column?
Re: Headlights cut out 1996 Dakota. [Re: MonGoo$e] #1198794
03/18/12 12:08 PM
03/18/12 12:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
the head light circuit is usually on a self resetting circuit breaker.
You have an issue that is making that breaker trip.
Find it, fix it. Probably a dirty connection in the circuit.
Don't be the exception.
