undercoating application #1198375
03/17/12 01:23 PM
03/17/12 01:23 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
I was at the shop yesterday and the guys were showing me a car they shot some of Ricks undercoating on and I thought it was a little "weak" looking, not nearly as rough or aggressive looking as I was led to believe to expect.
They said they used the Shutz gun so the tools are there but I was wondering if anyone has applied it and what can be done to make it appear more rough looking? Would it take mulitple applications? How about thinning or not thinning(I dont remember him saying how/what he thinned)
Thanks!!!
Re: undercoating application [Re: LimeliteAero] #1198376
03/17/12 05:00 PM
03/17/12 05:00 PM
Reynoldsburg< ohio
W
whitebird68 Offline
whitebird68  Offline
W
Reynoldsburg< ohio
I bought some of Rick's undercoating but am not going to use it. I sprayed a test section and agree with your assessment. I bought some "flex seal" in a can and find it to give a more accurate appearance.
Re: undercoating application [Re: LimeliteAero] #1198377
03/17/12 05:03 PM
03/17/12 05:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ricks stuff works great but it takes a specific method to apply it with convincing results, using Ricks tips together with practice will get you a long way towards making it look the part. If you just blast it on you won't get the desired results.
Re: undercoating application [Re: ScottSmith_Harms] #1198378
03/17/12 05:27 PM
03/17/12 05:27 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
whitebird68, can you post some pics of the results with flexseal?
Re: undercoating application [Re: NV69B7RR] #1198379
03/17/12 05:36 PM
03/17/12 05:36 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I find lower pressure actually works better, when the pressure is to high it sprays finer & flatter, lower the pressure & try again...
Re: undercoating application [Re: 1_WILD_RT] #1198380
03/17/12 10:50 PM
03/17/12 10:50 PM
SE Pa.
SE Pa.
thanks for the suggestions!
Ill also contact Rick for some advice.
Re: undercoating application [Re: LimeliteAero] #1198381
03/17/12 11:44 PM
03/17/12 11:44 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
the 3m undercoating i sprayed,seemed thin compared to factory,what i did was sprayed it on heavy,let it set for 10 min,used the wifes old hair brush(course) dabbed the entire area i sprayed(like sponging or ragging)it pulled the new undercoating up to be real bumpy,and blended perfectly to the factory spray
Re: undercoating application [Re: LimeliteAero] #1198382
03/19/12 09:38 AM
03/19/12 09:38 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You also need a larger nozzel than the standard shutz gun has. I drilled mine out.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
