Overcharging problem - question
#1198327
03/17/12 11:09 AM
03/17/12 11:09 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Hey Guys - Have a 67 Coronet wagon with a overcharging problem. Tried 2 new voltage regulators, 2 alternators, new engine wiring harness, sanded down mating surface of voltage regulator to ensure a good ground (with strap to engine) and still overcharging. It will pin the gauge needle to the charge side (18v) on aftermarket gauge and does the same with the factory dash gauge. It has also been confirmed on a auxillary gauge that it is in fact overcharging.
Havn't found any obvious wiring mixups, so I'm a little stumped as to why I still have an overcharging issue. Would it be easier to just get an internally regulated alternator, or is that just a band aid for a potential wiring problem?
What are your thoughts? Thanks
2 kids and a dog
Re: Overcharging problem - question
[Re: TonyS451]
#1198330
03/17/12 11:40 AM
03/17/12 11:40 AM
RapidRobert
Wiring prob. Disconnect ALL field wires then use jumper wires with alligator clips to connect batt positive to reg "ign". Jump connect reg "field" to alt field terminal. You're sure the alt/reg are grounded to batt neg properly. See if it behaves now & if so that'll confirm that it is a wiring prob. If not then the alt or the reg (more likely) is it. mechanical or electronic reg? Could have gotten a bad reg. If you confirm it is wiring then replace 1 jumper at a time with its OE lead till you find the culprit. Do the one at a time wiring changes with the eng off. I'm assuming your batt is fully charged and the large cables/batt terminals (positive an neg circuits) are cleaned. Sure sounds like a bad reg, something is full fielding it. EDIT do not go w an internally regulated alt
[Re: TonyS451]
#1198333
03/17/12 04:49 PM
03/17/12 04:49 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I know the OP states it's a '67 but does it have the original single field connection alternator or has it been upgraded to a dual field connection alternator?
[Re: TonyS451]
#1198336
03/17/12 05:52 PM
03/17/12 05:52 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
What does it charge with the voltage regulator unplugged? If it is still overcharging even while unplugged, the green field wire to the regulator is shorted to ground.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#1198337
03/17/12 06:04 PM
03/17/12 06:04 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Check the voltage regulator ground. If the ground is poor it will think the voltage is lower than it really is.
[Re: jamesc]
#1198339
03/17/12 07:31 PM
03/17/12 07:31 PM
John_Kunkel
Rio Linda, CA
Disconnect the ground control field wire (usually green) from the alternator terminal, if it stops overcharging the wiring is the problem. Check the control wire for a short to ground between the alternator and regulator. If it still overcharges with the wire off there is an internal short to ground.
[Re: John_Kunkel]
#1198340
03/17/12 11:23 PM
03/17/12 11:23 PM
RapidRobert
on the 2 field circuit system you pretty much just need switched 12V via the blue wire circuit to (1) the the top terminal in the VR triangle connector with the "top" being with the triangle being "up" like a pyramid and (2) T ing off of it to either one of the male alt field terminal (blue wire). Then the green wire runs from the "side" VR terminal to the other alt male field terminal. Is that what you currently have wired? That's all you need for the field circuit to make it charge
[Re: jamesc]
#1198344
03/19/12 05:21 PM
03/19/12 05:21 PM
John_Kunkel
Rio Linda, CA
If it's overcharging, both the regulator and alternator are getting battery voltage.
Since both the alternator and the regulator have been changed twice it's pretty safe to say there is a short in the field wire between the alternator and the regulator; most common place is where it runs along the valve cover.
