Bench top sealing #1197489
03/15/12 02:34 PM
03/15/12 02:34 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I'm building a wooden work bench for my garage and was considering using Eastwood trunk paint on the work surface to give some protection against spills and such. Anybody have any thoughts on how well this would work or suggestions for an alternative?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Bench top sealing [Re: MadMatt] #1197490
03/15/12 05:51 PM
03/15/12 05:51 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
nice good coat of marine varnish
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Bench top sealing [Re: MadMatt] #1197491
03/15/12 06:01 PM
03/15/12 06:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Forget the trunk paint, it washes off with water! In fact, forget about coating it at all ... the last thing you need is paint chips or dissolved paint on your parts. Let the grease and oil from your parts be the treatment. You might also consider a piece of sheetmetal for the top or even a couple of dollar store rubber boot mats - they're ok with oil and solvents and have a nice ridge around them to keep liquids and parts from ending up on the floor (as well as protecting the bench top).
Re: Bench top sealing [Re: Stanton] #1197492
03/15/12 06:36 PM
03/15/12 06:36 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
you might want to try this but i warn you it's addictive. www.garagejournal.com
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Bench top sealing [Re: 68 Sat] #1197493
03/15/12 07:22 PM
03/15/12 07:22 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Great website. Thanks!
Re: Bench top sealing [Re: Stanton] #1197494
03/15/12 07:22 PM
03/15/12 07:22 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Makes sense to me. I'm going the route you suggested. Thanks!
Re: Bench top sealing [Re: MadMatt] #1197495
03/15/12 07:36 PM
03/15/12 07:36 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Matt, you have multiple options:
Oil the wood surface with the proper furniture oil.
Find a sheet of aluminum, stainless or galvanized metal and screw it to the wood.
Use the vinyl/plastic stuff sold for garage floors.
Paint the surface with a 2-part epoxy or whatever.
Check Home Depot/Lowe's for a sale on counter tops, especially an ordered one that wasn't picked up.
A few lengths of 1/2x1/2 aluminum angle can be used for the edges to keep stuff from rolling off.
The boot-mat idea is probably the cheapest to do.
Re: Bench top sealing [Re: topside] #1197496
03/15/12 09:11 PM
03/15/12 09:11 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I was just thinking maybe linoleum or vinyl floor tiles. Any thoughts on that?
Re: Bench top sealing [Re: MadMatt] #1197497
03/15/12 11:05 PM
03/15/12 11:05 PM
A collage of whims
A collage of whims
Both of those materials gouge fairly easily, seams trap liquids, and they probably won't like solvents, but for something that would be kept clean & dry and not pounded on, peel & stick tiles would work and there are a lot of color options...heck, faux slate would be amusing...all depends on what you're going to use the surface for.
For that matter, think about what's going under the bench before you set a shelf height, or make it adjustable. Start looking for wall cabinets, too, so I don't have to bust your stones when I inspect the place!:)
Re: Bench top sealing [Re: topside] #1197498
03/15/12 11:23 PM
03/15/12 11:23 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
...so I don't have to bust your stones when I inspect the place!:)
Not worried about your inspection, your old and blind anyway. I'll just keep the lights low.
Re: Bench top sealing [Re: MadMatt] #1197499
03/16/12 12:00 AM
03/16/12 12:00 AM
A collage of whims
A collage of whims
Leave my sex life outta this. Hey, speaking of sealing, do your floor before the Dart leaks all over it. You preppin' a room for Scollo?
Re: Bench top sealing [Re: topside] #1197500
03/16/12 01:56 AM
03/16/12 01:56 AM
USA
big-block-dave Offline
USA
No bare wood, i used 3/4" plywood and put a clear finish on it like polyurethane. With clear just a damp rag wipes up the dust/dirt. Wipe grease/oil rite off. I use old cafeteria plastic trays when working on like a carb or what ever might have chemicals or gas. Bare wood will look like crap once the dust and dirt sits/works into it.
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: Bench top sealing [Re: MadMatt] #1197501
03/16/12 02:19 AM
03/16/12 02:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I glued some really thick floor covering (linoleum?) on the work top. It's really easy to keep clean.
Re: Bench top sealing [Re: topside] #1197502
03/16/12 12:00 PM
03/16/12 12:00 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I had the floors epoxy sealed before I moved in. As for Scollo, Sammy doesn't use his dog house much and it is quite roomy...
Re: Bench top sealing [Re: big-block-dave] #1197503
03/16/12 12:01 PM
03/16/12 12:01 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Good points, I'm going to have my drill press, bench grinder, etc. mounted up there so there will be lots of crap to get worked in.
Re: Bench top sealing [Re: MadMatt] #1197504
03/16/12 01:46 PM
03/16/12 01:46 PM
hooziewhatsit Offline
I put some left-over linoleum on the bench at my previous place. Seemed to work pretty well, and not too hard to get clean. It was starting to stain in a few places by the time I moved though.
I may just varathane the next work bench I build
Re: Bench top sealing [Re: hooziewhatsit] #1197505
03/18/12 02:31 PM
03/18/12 02:31 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I put 1/4" piece of plexiglass on top that I attached with recessed screws and I just swap out sheets of cardboard when needed. always looks fresh.
Re: Bench top sealing [Re: hooziewhatsit] #1197506
03/18/12 09:40 PM
03/18/12 09:40 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I was looking at the Armstrong website and it appears commercial grade vinyl flooring may be the way I go. It has high resistance to chemicals including caustics and acids. I think I can pick up enough vinyl sheet flooring to do the job for about 30 bucks brand new.
Re: Bench top sealing [Re: MadMatt] #1197507
03/18/12 10:32 PM
03/18/12 10:32 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I coated my bench tops with roll on truck bed liner. It's really durable and wipes clean. Seems to be chemical resistant too.
One great tip I got when making my benches was to make the top easily replaceable. Use a thin final layer of plywood or OSB that you simply pull off and flip over or replace when it gets too trashed.
Paul
'69 Super Bee 383 EFI Turbo
Re: Bench top sealing [Re: Black_Bee] #1197508
03/19/12 05:27 PM
03/19/12 05:27 PM
A collage of whims
A collage of whims
Matt, if you go the lino route, you might want to run a molding around the perimeter; keeps things from rolling off, and will keep the edges from curling up. Look for something with an L shape, aluminum, kind of like the old formica tops used to use.
